Question about Hotpoint HSS25GFP Side by Side Refrigerator
Top part in freeze and food chambers donot work
Posted by genshan on
D. Floyd Kolb
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 14, 2011
Daewoo FPN-Q19DAVS American Fridge Freezer - Fridge freezing everything
I would say that the air damper valve has failed and stuck in the fully open position. It fits between the freezer and food cabinet. It has a little door which slowly opens or shuts to regulate the temperature in the food compartment. If it sticks open, the food side (Especially the top) will start to freeze up. I haven't done work on your model but it will be at the top corner of the food compartment behind the top inner panel. You will have to remove that to get to it. Its a little rectangular box with a door that opens and shuts and usually a wiring connector plug just above it.
Sep 30, 2018 | Daewoo Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Is there a difference between freeze-dried and dehydrated food?
Yes there is, in freeze-drying process they use a cold temperature and in dehydrated food they use warm temperature. In the freeze-frying process the fresh foods are frozen first then the moisture removed in a vacuum chamber and since the food remains frozen during the process, the food's cell structure don't change.
Aug 09, 2012 | Camping, Backpacking & Hiking
My LG19320 Top Freezer Refrigerator is freezing all the food in the lower part of the fridge. Any idea what may be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | LG LRTN19320 Top Freezer Refrigerator
I have a homewell retro 50"s style slushie maker and it didnt come with an instruction manual... would u know where to find one online? thanks :)
I don't know where to find one, but...
Add 6 table spoons of rock salt or table salt in the middle chamber and 1/2 cup of water. Then top it off with ice to an inch below the rim. Then, fill the outside chamber with your favorite sugar based liquid and slide the switch to freeze for app. 20 minutes. slide to dispense when it's the right consistency. Enjoy :D
Dec 26, 2010 | Food Mixers
My freezer will not work all my food is spoiled. I donot know what to do? Compresor does not start,light is on their is power but will not freeze.
you may just need a new relay and overload
goto ww3.sears.com
do a modle search your parts is found rtight on the compressor itself
without knowing more this is where i would stasrt
Oct 08, 2009 | Freezers
Hay
Battery contacts can be improved with metal foils to pack out the chamber. Make sure all contacts are clean- use a pencil eraser for bottom the the chamber. Pack out top of batteries under the cover with foil- do not cross connect . When closed press the cover with your fingers.
Jul 19, 2007 | Mustek MDC-6500Z Digital Camera
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
