Ovens Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
Anonymous
Level 3:
  • Master 576 Answers
  • Posted on Feb 14, 2011
Anonymous
Master
Level 3:
Answers
576
Questions
0
Helped
204001
Points
1663
Which plug you use depends more on the outlet in your house than the oven usually. If This is a new oven with digital controls, 4 is preferable (I've seen a digital dryer blow the boards because a 3-wire lost it's ground) but if the outlet is 3, you don't have much choice but to go with 3 unless you rewire the outlet back to the fuse/breaker box. As long as it's in good condition, 3 should work fine.
1helpful
I have an Old Lang EHS-T convection oven and need to replace the element. The part # is 2n-11090-24. I'm having difficulty finding this part. Is there a substitute I can use for this element?
Once after checking that the specs are the same the parts can be used in different equipment despite the various brands the spec are what is important alone with the dimenssion so that it can fit
What size cable is required for a double oven of 5.7 kw total rating
It does not depends on the Power, kW but on the current A .
With 240 V you have a current of almost 24 ampere. With 110 volt you have a current of more than 50 ampere. So you need a cable at least twice as thick. The you have the law ad regulations in your country. Leave it to the installer to decide what is save. When in a country with 230 to 240 volt I would go for at least 4 mm squared. and when in a country with 110 volt, for the next step, 10 mm squared although that could be on the edge. Play safe? pick 16 mm squared.
Feb 27, 2015 • Ovens
Thermador c272ub double oven is it single fase wireing
yes,the black and red era the 2 wires that supply 120 volts each for the required 240 volts necessary to operate the oven,the white is the neutral wire and the green is the case ground wire,and it should be connected to any metallic part on the oven not with the white wire,only if the power supplying this oven comes directly from the main power panel in the house and isn't off a sub panel before the oven can this be considered ok to be connected together
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2answers
Model ww2460B double oven. need thermostat 71001138. can I get it anywhere?
Good luck with that!!! I had the same problem and scoured the internet for a solution. If you can find a used or rebuilt part you may be in luck. The thermostat on the left is a 6 pole one for the upper oven while the one on the right is a 4 pole for the lower oven 71001126. I doubt you can substitute the one for the other and give up the convection and self cleaning functions. Let us know if you find a solution or buy a new stove. Sears has a few 24 inch double ovens left, as the world is moving to 27 and 30 inch ovens.
I trust that your voltage system in your house is 240 volt. The number of wires or the size of the wiring will depend purely on the kilowatt rating of the oven. Normally on a 240 volt system a 3 wire 32 amp circuit will generally be used on ovens/ranges up to at least 6.0 kilowatt. If you need more information please reply.
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 • Ovens
2helpful
All the lights, display, etc. work on the oven but no heat
First and foremost check the breaker box. Ovens use 240 volts which is a double breaker in the box. Just to be safe I would click both breakers off and then back on together. If this doesnt work turn off the power and have someone help you pull the oven out and check your plug or connection. You may be dealing with a broken wire in the junction box due to the power outage. If you have a volt meter turn the power on SAFETLY and test if your getting 240 volts. If the connections are good (including the one from the juction box to the stove itself) and you are getting proper votage, unfortunatley you are going to have to get a new control. What happens is with only 120 volts going to the oven everything runs but your elements (they utilize the 240 volts to heat). You can tell time or use the timer but without your full 240 your turkey aint gonna cook. There is 120 volts coming coming from each of those breakers you checked in the garage. Bottom line is the chances of both elements going out at the same time are slim to none and I feel you are probably dealing with a broken wire.
Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
