Question about HTC Touch Pro2 Smartphone
The screen is freezing when I use the keyboard or open it. This screen has glitches and doesn't work on some spots. Also I put it on vibrate and it doesn't work. And people can't hear me when I call them.
Posted by tbyrd102 on
Anonymous
    New Friend:
  • 11 Answers
Master reset is probab or sometimes if you have way to many messages delete those and see
Posted on Feb 14, 2011
REPOST: Just reset start button by opening and removing and then reinstalling internal battery. Now it powers on, but keyboard does not work touchpad does work.
Try a hard reboot that sometimes fixes glitches including keyboard issues. To do this power down PC, unplug and remove battery. Then hold the power button down for 30 seconds, put battery back in and then plug the PC back in. Power up and see if keyboard works now.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Feb 16, 2016 | ASUS Computers & Internet
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
All of my other N64 games work perfectly, but when I put in Donkey Kong 64 it always freezes during the 64 logo or the Dolby thing. I tried trading it in for a different one, but the second one freezes in...
Well there could be an internal issue with the console then or video games consoles are senseitive to heat and it could be an over heating issue. Dust acts as a baricade and it makes video game console over heat 10 times faster than their normal rate.
Jun 07, 2011 | Nintendo 64 Console
Hp laptop screen gone sideways & mouse not working
Right click on an empty spot on the desktop, scroll down to the graphics control panel, this may be Ati or Nvidia. Open the control panel amd look to the choices on the left. There will be a choice to either "Rotate Display" or something about "Screen Orientation", change the rotation to "0" degrees or whatever puts it upright.
Jan 02, 2010 | HP Computers & Internet
Vibration on screen
You have a bad LCD screen and need to replace it. See if it is still under warranty from the Manufacturer. Not much more you can do. Good Luck...
Nov 16, 2009 | Dell Latitude D520 Notebook
Screen glitches and freezes. also RROD
RROD red ring of death -= over heating, if your mech minded, you can buy fix kits which work 95% of the time from trade me or ebay for about 50 NZD that allow the heat transfer to stop, also while your there upgrade your cooling system, very easy, computer fix shops can do it for about the same price. or just open cased with a wired in 5 dollar fan can even do the trick. but dont try the towel method, will wreak it for good
Jul 11, 2009 | Microsoft Xbox 360 Console
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
My computer freezes up with a blank screen and nothing on the keyboard will work until i hold down the power button for about 10 seconds and it shuts the computer down
Right click on a open spot on the desktop. Click on personalize. (that is with a left click)
Then click on screen saver
At the bottom of that window, is a link that says "Change power settings"
Click on that.
Change power plan.
Put Turn off the display - change that to NEVER
Put the computer to sleep - Change that to NEVER
That should fix your problem.
Apr 06, 2008 | Computers & Internet
HTC Touch Pro2 Smartphone Logo
Top HTC Cell Phones Experts
Lawrence Oravetz
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
