SOURCE: Olympus Stylus 710- no flash mode
I;ve been on the internet all morning researching the same problem. It appears it's a curcuit related problem with the flash. As of know, haven't got a solution other then buying another camera or taking paictures in manuel mode without flash.
SOURCE: burst mode on Panasonic Lumix dmc-fx50
I have, after sifting through the 144-page manual, figured out what the problem is! At some point you must have set the "Auto-Bracket" setting to on - I did the same thing! To turn this off, put it in any of the Scene or Manual Exposure modes, then press the up (↑) key until "Auto-Bracket" comes up. Then, using the left or right (←,→) keys, set it to Zero (0). This should hopefully solve your problem! :)
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: Panorama Feature on Olympus Stylus 840
Forget the in-pano function and use a free stitching program off the internet. When shooting panoramas, you need to be in aperature priority or manual mode so as to keep the exposure consistant, especially going into the sun or away from it in your pictures. Although this is good practice, it is not needed for a few stitch programs as they average out all the exposures and make the entire pic uniform. This works pretty good in all but the most demanding exposure swings.
SOURCE: I took pictures with the multi-burst function. Is
They are single shots...just a lot of them.
