1990 f 150 6cyl starts stay running while holding key on start let go to drive and stops running but every thing is on but dont stay on the run position
Very possible bad head gasket and fowled out plugs and/or O2 sensors. Remove spark plugs and check condition of them and pull O2 sensor to see if it is green from antifreeze. Good luck.
Very possible you have water in the fuel tank. You might want to drain all the fuel out of the tank, install fresh gas and new fuel filter. If there is a lot of water in the gas tank, gas dry will not correct the whole problem then you now have gas that does not have the octane/combustionability to maintain the vehicle to run properly. Good luck.
Checked the plugs looked good. Checked cap and rotor also seemed fine. The water is clear looked like condensation and had no smell to it. I only had truck for 5 weeks, it was acting up and i added dry gas / fuel injector cleaner. Seemed to clear up. then 3 days ago started bucking and skipping, now it wont stay at idle and dies under load.
