Hi, If the belt shows no sign of wear and its not torn or cracked then you have nothing to loose in trying to put it back on, some machines have a tensioning bolt that can be undone slightly so the motor can be moved down to tension the belt if it seems loose and others do not, but if you anre unsure you can always get a new belt anyway.
Another consideration is that the machines bearings may be getting worn, making the pully go out of alignment (hence the belt coming off), check this by gently pushing the front rim of the stainless tub up and down, if you can feel movement it may be worth getting it checked for bearing failure with a view to getting them replaced.
Hope this helps.
You likely will need a new belt. A belt in proper shape will hold its shape and form so that it won't elongate very much. Slipping off is a sign that it is stretching excessively. It could also be a sign that a bearing is going out on either the motor or the transmission and is allowing the pulley to wobble, which can throw a belt.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
