Question about Philips Audio Players & Recorders
My turntable runs fast. At the 33 1/3 selection speed, it actually runs at 34 1/2. There must be a way to adjust that speed. Can you help? Tks, Tom
Posted by roodee4345 on
Grubhead
  • Philips Master
  • 5,700 Answers
There are generally two ways the speed of a turntable is set. Firstly in the power supply section, you might find two presets one for 45 and one for 33. These are adjusted by placing a screwdriver in them. The other way is by presets in the bottom of the motor. This generally only applies to the 9 to 12 volt motor types used mostly on belt drive turntables.
Posted on Feb 16, 2011
33 Records are playing a bit too fast on my Wockoder Record Player... Is there any way to fix this?
Lots of quality turntables have a speed checker and a limited amount of speed adjustment.
Many ordinary record decks use a synchronous motor, the speed of which is regulated by the Hz of the mains supply and with mostly fixed gear ratios it is impossible for them to run faster - slower is the usual problem.
I expect there will be types driven by a dc motor and regulated by a switch mode power supply but I know nothing about them.
I suggest you begin by learning something about your turntable.
Dec 27, 2017 | The Audio Players & Recorders
How do I adjust the pitch / rotation speed for the turntable of my Emerson NR305TT ?
If the pitch is adjustable then there will be a little round knob to adjust it near the pivot of the turntable tonearm. If not the pitch is not adjustable.
Jun 23, 2016 | Emerson Nr305tt Heritage Home Audio System...
My turntable dont have a belt and is spining to fast on 33/45 can you please help me.
It's a direct drive turntable. That means the platter is actually mounted directly to the motor spindle, and electronics control the speed of the motor -- no belt needed. Most likely the electronic speed regulator has failed or is out of adjustment. Take it to a repair shop and get an estimate on how much it will cost to fix it. Sometimes it's cheaper to buy a new one than it is to repair an old one.
Sep 30, 2014 | Audio Players & Recorders
Otpimus 1000 will play 45 speed but not 33?
That is a belt drive unit. If there is no speed adjustment. You need to take the platter off and check the capstan and belts.
Sep 01, 2014 | Audio Players & Recorders
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
My audio technica turntable is playing records too fast. how do i fix this?
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
Jan 08, 2011 | Sony PS-LX250H Turntable
How do you adjust the speed of a Memorex 2601M?
Go inside and look at the main board you should see two/three presets, one for 45 and one for 33 etc.
If not look at the top of the motor for a small hole, it might be covered with a label.
Nov 24, 2009 | Audio Players & Recorders
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
Top Philips Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
