Question about Garden
Beckett 7060310 PUMP-G535AG - Garden
Posted by lenbeeler on
Joseph Mueller
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
They cost $50 or less at amazon.com good luck
Joe
Posted on Feb 14, 2011
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
[email protected]
Good Luck
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: [email protected]
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett at[email protected]
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: [email protected]
Or write to them at the address above.
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Garden Logo
Top Garden Experts
john h
wadingriver
wadingriver
ray gallant
