Please explain the issue a bit more.
Are you not able to find the wireless signal at all now or they are visible but you are not able to connect?
If they are not visible, then have you checked the device manager and see if there is any wi-fi card mentioned under Network Adapters or not or is there any question mark or exclamation mark on it or not?
~To download drivers and specific
software; Always get your drivers
from the manufacturer of your Laptop, Notebook or Desktop. If you were to log on to the acer.com
web site, usually one is able to download if
available, by model number,
All available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing. This is the best way of ensuring up to
date drivers for your system and they are free of charge! There
are no XP drivers to be found with Microsoft as XP is no longer
supported. Some
manufacturers may have a limited number of Drivers still listed. Windows7 however, will run in XP compatible mode if you install that part of the programme. (Win7 Ultimate) I hope this helps.
The connections are visable...some of the time. When they are, I can connect. (I know, this sounds like maybe there is a problem with the router, but I'm connected on another laptop right now and my netbook is stiil unable to find any networks...) I was able to install the drivers, and if I try to update it tells me they are up to date... Trying to get online with a wired connection didn't work either...
