Thanks for your reply, a local workshop has just fitted new brakes and
discs and tested all breaks on their MOT equipment, every thing tested
OK and the ABS is working, but still the noise persists!
The car would not "talk" to their computer therefor, they could not
check for an electrical problem that may be present with the ABS, could
this be causing the noise?
The description is a bit vague, but check that all the brake pads have the vibration plate between the pad and the piston. If one or more of the plates is missing it can cause the pad to vibrate under braking. Whilst you are checking make sure that all the calipers are tight on the the mounting bolts.
There
are many possibilities that can cause car to make noise.
There
is N-number of possibilities for the car to make thud noise or any other
kind of noise.
For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------
Click
the link below: -----
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like
driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for
Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
4X4 Truck makes roaring noise in
the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under
dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and
front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan
belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While
Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Car makes whining noise like driving on rough pavement?
What are the possibilities for Clicking noise in car?
4X4 Truck makes roaring noise in the front end?
Heater makes clicking noise under dash on Ford Explorer?
Clicking noise under dash and front defroster not working?
Car Alternator Bearing Makes Grinding noise?
Engine makes noise and Cooling Fan belt Breaks?
Vehicle Makes Clicking Sound While Taking turns?
ABS light comes on and Car makes Grinding noise?
These will help.
Thanks.
