Question about Pride Mobility Products Jazzy 1170 XL Plus
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally engaged.HELP
Posted by limpingti214 on
Anonymous
    New Friend:
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Posted on Mar 29, 2011
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Apr 29, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 1170 Powerchair
Just wrap your wrist with an Ace bandage. LOL
Sep 27, 2017 | Pride Mobility Products Jazzy 1170 XL Plus
CONTROLLER LIGHTS UP OK AT START. BUT IF U MOVE THE JOYSTICK, ALL THE LIGHTS FLASH RAPIDLY AND IN UNISON. WHAT FAULT DOES THIS REPRESENT?? THX U
I think you might have a joystick fault but first make sure that the chair is not in freewheel. If the chair is not in freewheel then you have a joystick problem and it will have to be replaced Hope this helps
Feb 12, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The power chair only blinks three red and one yellow light and does nothing else
The flash code you are seeing is indicating that there is a right motor fault. I would call the company that sold the chair to you for a repair and or motor replacement. There might be a possibility your insurance will pay part of the cost of the repair.
Hope this helps, if so, please rate this solution to help others who may have the same question to better help them.
Thank you for using FixYa.
Flavadave75
Dec 25, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Jeff Bird
Don A
Don A
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
