Question about Sony VGNAR230G PC Notebook
I need to replace the hard drives on this laptop but my tech person tells me that I need a special adaptor that connects the laptop to the hard drive(s). Can you assist as to where I can find this item? Laptop model number PCG-8W2L.
Posted by stevejackieg on
Anonymous
    Sergeant:
  • 201 Answers
What a bull, you need to buy a Sata drive
http://www.laptoppartsexpert.com/search.html?q=VGNAR230G
Posted on Feb 13, 2011
Replace hard dirve for static drive
identify the connector .if it is IDE connector purchase ide to sata convertor adaptor and then connect your static drive.otherwise you can directly connect your drive.no need of any change in setting
2answers
Help my laptop isn't working
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Wrong adaptor plugged into hard drive
you can use a external hard disc connector ,,, but still you must open the box ,, i think the guarantee is already void ,,, cause misuse is not guaranteed any way you must ask about the guarantee thing ,,,
Fujitsu Hard drive MHK2060AT not being read. =/
In a simple way the hard drive doesn't need a driver. Maybe the hard drive cable are not connected properly. You need to check the hard drive if is it connected correctly. Try to make also the BIOS and make your hard drive in to first boot.
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
1helpful
Dell Latitude C510/c610 Can this notebook book from the USB Port? I want to install Fedora Linux on my newly repartitioned HD but I can't read the DVD (don't have DVD drive available).
When you want to boot to the USB hard drive just have the drive installed, reboot the system, select the appropriate function key to go to boot options (should tell you what to press in the beginning of boot up) and select USB hard disk.
An important thing to note: Most Linux distributions won't boot from a USB hard drive or thumb drive without a special program for unpacking it to the USB Hard disk. Check with the distribution website for special instructions.
Good Luck,
NOLA Tech
1helpful
Getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
How to disasemble the unit ?
It is very simple. Just go to the bottom side of your laptop and check under the door that is about 2.5 in by 4.5 in and remove the cover. pull the screws that hold it down and slide it back and out. It may have a special adapter . mark how it goes on and remove it. put the adaptor on the new hard drive and reinstall it just as you removed the old one. Fasten it down and replace the cover. Now you are ready to boot your computer and install your operating system.
I dropped the grandson's external drive.
If the hard drive itself is damaged, recovery of any data on it may only be possible by sending it to a business specializing in such. I'd suggest opening the case of the unit, and you should find that the drive in it is what is in a desktop or laptop computer, with the appropriate electronics to adapt it to USB. There will be at least one cable connection to the drive- make sure it is properly seated. I've seen an instance where the only problem was a partially disconnected cable. Another possibility, is, if it is a standard drive, to let a tech savvy person take the drive itself, and connect it to a standard computer, and see if it is then readable. If so, data can be recovered.
Sony VGNAR230G PC Notebook Logo
Top Sony Computers & Internet Experts
Michael Thomas
Michael Thomas
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
