Question about Broksonic CTGV-5463TCT TV
Remote control does not work on my TV. How do I program it?
Posted by johnnaf on
  • johnnaf Feb 14, 2011
    It is the original remote control.
    Top Expert:
  • Broksonic Master
  • 76,637 Answers
Hello
What is your need. It is not clear from your post. Which remote do you want to programe with your Broksonic TV? Is it a universal remote control, or it orginal remote control handset.? If universal remote control, which brand do you owns?. Please provide these details through Fixya. OK.
Posted on Feb 14, 2011
  • The Knight
    The Knight Feb 14, 2011
    Hello
    If it is its original remote control, it should work without any problem with your Broksonic set. Just check its cells in its battery compartment first. Replace them with new ones. Then check your remote control's functioning. It can be checked very easly if you have a cellphone with camera option. Put it on camera mode, and place the remote control at about one feet away or so, press each button on the remote control. You can see infrared rays' image on the screen of the cellphone camera. Check each and all buttons for proper functioning this way. If it does work properly, the remote sensor inside your Broksonic TV is faulty. It doesn't receive the infrared signal from your remote handset. It is three terminal component, can be located just beneath the infrared window at the front of your TV. To access it and replace it, you have to open your TV. This sensor can be desodered out from position, and can be replaced easly. It is available in most of the electronic sparepart shops.
    If you need anymore assistance, feel free to get me through Fixya. OK.
2answers
Need to reprogram my remote to my Samsung tv. No manual
How To Program Your Samsung Universal Remote
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 5, 2013 - You can program your Samsung television universal remote control to... Note: Your remote may have separate buttons labeled Cable, DVD, ...
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote-c...
DirecTVHow do I program my DIRECTV remote control? Print. Email ... DIRECTV RemoteSetup to Change the TV Input Source. If you can ... Still need help? Contact us ...
HOW TO RESET YOUR TV REMOTE CONTROL - YouTube
? 3:15
https://www.youtube.com/watch?v=CnFfo8-3GC4
Feb 11, 2012 - Uploaded by SlimfromMrRemote
However, if this does not work and you do need a new TV remote,... thank you so much my control samsung tv AA59-00580A its working again ...
HOW TO PROGRAM SAMSUNG SMART REMOTE - YouTube
? 8:35
https://www.youtube.com/watch?v=asgS7NzQLi4
Jun 28, 2012 - Uploaded by Tampatec
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
2answers
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
2answers
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
2answers
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
IR Remote Control Remote Control: my control is not working...
Guest
I have provided instructions on how you can program your remote to your TV or readdress to your receiver. Readdressing your remote to your receiver begins with step 5; programming to your TV begins with step 6.
Program remote: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
I hope this helps.
Ray Calo
DISH Network
1helpful
2answers
Codes
I NEED CODES TO PROGRAM MY TV W/ REMOTE CONTROL URC-4021BOO
2helpful
37helpful
4answers
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Broksonic CTGV-5463TCT TV Logo
Top Broksonic Televison & Video Experts
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
