Question about Malber P21 Front Load Washer
Washer does not spin at high speed with a load in it but it spins at high speed when empty
Posted by gilbertfoo on
john_cross
    Brigadier General:
  • 6,277 Answers
This sounds very much like the belt is slipping.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Feb 13, 2011
5 Related Answers
Anonymous
  • 136 Answers
SOURCE: Kenmore 20722 Motor Coupler or Cluch assembly?
Its easy to check the coupler, i would do that first to make sure then if its ok , well clutch. Kenmores, a.k.a. whirlpool's , are very common to have both problems. Just remove da pump and hoses, then remove the motor and check the coupler.
Posted on Sep 21, 2007
SOURCE: Whirlpool won't spin at high speed
$100 to change a coupling? Little steep don't you think? That's like a 10 minute job
Posted on Feb 07, 2008
Ian Jones
  • 77 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Posted on Feb 10, 2009
J. Bradshaw
  • 121 Answers
SOURCE: washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
Posted on Jun 02, 2009
Anonymous
  • 3085 Answers
SOURCE: washer drum very loose even when empty. shakes
It sounds like one or more of the shock absorbers is broken or has come loose from its mount.
Posted on Feb 20, 2010
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Malber P21 Front Load Washer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
