Question about Dryers
Can you give me information on how to replace the belt in the dryer.
Posted by mbaluyot01 on
Anonymous
    New Friend:
  • 17 Answers
From back of dryer remove access door to disconnect belt from motor & tensioner.(remember how belt was placed on tensioner & motor pulley) You must remove dryer front panel ( look for 2 screws at bottom of front panel) Pull out from botton of front panel to remove, exposing drum end retainer brackets, remove brackets, allowing access to drum. Slide old belt off & new one on.
Posted on Feb 13, 2011
Trying to replace a belt, but there is a wheel with a bracket on it that iam not understanding how it goes together
Hi collins t2..
You did not say what dryer you are working on so it is very difficult to give you the information you need to complete your job as there are many different ways to route the belt.
I will send you to a webpage to see a picture of how various dryer belts are routed.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 23, 2011 | Dryers
DRIVE BELT REPLACEMENT; HOTPOINT DRYER
The dryer is the same as a General Electric (GE) - Large Capacity Models 1970-1990 here is a link:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 04, 2011 | Dryers
Belt broke on dryer and cannot figure how to put back on pulley
You give no information on your machine, but normally you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Mar 21, 2011 | Whirlpool Dryers
When belt breaks is there an automatic shut of switch because the dryer will not run?
Yes on MOST dryers there is a belt safety switch. It is there to prevent you from using the dryer with a broken belt. (i.e heat but does not tumble) When the belt breaks the idler pulley arm drops down and trips the safety switch.
If you need help with parts, and replacement belt procurement / owner replacement of the belt, we need your model number please so we can pass you the correct information.
Just respond here and someone will help you.
Kelly
Aug 16, 2010 | Dryers
I'm trying to change the belt on a Performa dryer. Model # PDET910AYW Serial # 11938312JN. I've searched the website for the do it yourself belt change but this particular dryer isn't listed with the...
looked up your model and found this information...
http://www.appliancepartspros.com/whirlpool-belt-cylinder-wp40111201-ap6009126.html
there is a video on this page to show you how to replace the belt.
hope this helps! belt replacement is never too much fun
but not awful!
Best to you.
Feb 26, 2018 | Dryers
Squeling when drying clothes
u need to replace the dryer drum belt.
Mar 05, 2010 | Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
My kenmore dryer won't spin or tumble. The motor runs but no tumbling. I heard a loud bang but didn't know what happened. çould it be the belt?
If the drive motor is still running, the loud bang you heard was either the belt breaking, or slipping off the idler pulley. I will need a model number in order to give you spcific details on how to open the appliance in order to inspect and replace your belt. If you need assistance on how to properly route the dryer belt on to the drive motor shaft and idler pulley, repairclinic.com has dryer belt diagrams listed under their "Special Features" section. Just click on the "Repair Help" link at the top of their web page, to start. You will need either diagrams H, B or K. Its hard to determine which diagram without your model number. Post back with your information and let me know.
Jul 11, 2009 | Dryers
Drive belt on Tumble dryer
YOU NEED TO POST YOUR MODEL NUMBER AND THE MAKE
Apr 10, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
