Question about Refrigerators
Haier Refrigerator: 115 volt; OF612D. When plugged in and turned on it does not power up or show any signs of electrical usage. What is the problem and how do I fix it? [email protected]
Posted by twoplaymusic on
5 Related Answers
Anonymous
  • 91 Answers
SOURCE: ON sign shows blue screen only in my MP3 player
This looks like the software has corrupted on your mp3 player. In order to get it working again you may need to format it by either using software which came with the mp3 player when your brought it or use the simple way through "My Computer".
If you haven't got any software follow these simple steps. Click "Start" located at the bottom left, now click on "My Computer", now when your on My Computer look for your mp3 player but don't click on it just find it on there (It's usually called "Removable Disk" right-click on it and click "Format".
Allow it to format then try unplugging it and switching it back on and see if it's fixed the problem.
If it doesn't may need to download some firmware of the manufactuere website. I have found some firmware which may be yours you may need to download and check
https://system.netsuite.com/core/media/media.nl?id=16075&c=432868&h=68a87fdefb1fe2d5903b&_xt=.zip
Good luck. Hope my solution was helpful.
Posted on Oct 26, 2007
Anonymous
  • 146 Answers
SOURCE: fisher-paykel electric dryer
Try turning it on while holding the door switch and give the drum a spin. If it starts you will need a motor if it does nothing then look for a solenoid.
Posted on Dec 22, 2007
Anonymous
  • 1861 Answers
SOURCE: usage of some switces
The TRAC OFF switch turns the Traction Control off.
THE ECT /Power switch stretches the 1-2 and the 2-3 automatic trans upshifts longer (useful if you are carrying a heavy load, otherwise, it does nothing)
The O/D is the overdrive. This gives you maximum MPG when driving. It is sort of like 5th gear in a manual trans car.
Posted on Sep 10, 2008
Testimonial: "Thanks for the useful information. It is really great and helpful "
Anonymous
SOURCE: refrigerator does not cool
little info to give a good diagnostic
here some hints:
1) try to defrost it
2) check the grid at the back that normally radiates the heat from the fridges cooling liquid, and undust it,
3) if it is a fridge/freezercombo, then it can be that the defrosting needs to happen in the freezer compartiment, as both sides most likely do share the same cmpressor
4) eventually your fridge lost its freon or other cooling gas.
5) could be the termostat also
Posted on Dec 28, 2008
MOTORWIZJ
Jay Finke
  • 1391 Answers
SOURCE: i'd like to know how to change a 115/230 volt pool...
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
Posted on May 29, 2010
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
2answers
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
I have an True t72f bought in late 2005 it as a nema 14-20p plug on the data plate it shows 115/208/230 volts?? how do i know what to hook this unit up to ??
If the plug has 4 poles on it, that means it should be connected to two lines of power, one neutral, and one earth ground. The unit probably has a 208-230 volt compressor, with 115 volt control and heater system. Let me know if you need more info
Brew light does'nt go on and water doesn't heat up and water doesn't come out
Possible bad switch or bad power cord. Remove the bottom plate and look for ~115 volts AC at the ends of the power cord with a voltmeter (cord plugged in). Make sure the outlet has power where plugged in. If you get voltage, then turn the switch on and measure the voltage across the switch terminals. If it reads 115 volts, replace the switch. Good luck!
My Codegen Switching Power Supply 350W Model 300Xi Atx2 o3 (P4) is smoking when I turn on my PC
Using 115 volt or 208 volt switch?Found on back of supply
Is the fan clog with dirt and is it turning?
Check your wiring as some supplys can be wired for 115 volt or 208 volt.you want 115 volt.
1helpful
2answers
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
4helpful
3answers
POWER SUPPLY PROBLOMS!!!!!!!!
Unless your household electrical service is running at 230 volts, there's absolutely no reason to set your supply for 230. When you choose the 230v setting the supply REQUIRES 230 volts to become operational...Which is not going to happen on a 115 volt service.
Generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
Circuit breaker
ngfam1
Happy to assist,
HOW MANY BTU IS THE AIR CONDITIONER?
And is it 110 or 220 line!
If it is using 110 or 115 volts like normal house current and it throws circuit breakers in your electric box,then you need to run a dedicated line just for the Air Conditioner!
Usually this happens to 110 -115 volt air-conditioners that are more than 12,000 BTU and do not have a dedicated electric line in the wall only for the air conditioner!
New air conditioners have a circuit breaker built into the units plug!
And I have seen some that throw that breaker to off frequently even if it's only an electric surge! Which it should not do!
if its the case and it's new, take it back to the store and ask for a different model, size, or brand!
Fedders had an 18,000 BTU/ 110-115 volt unit that did this with every single unit last year! I stopped selling that unit only!!
Ngfam1
PLEASE GIVE ME A GOOD RATING HERE FIXYA.COM BEFORE YOU SIGN OFF!
you can just use it as is as long as it survives!
45 Pint Capacity, Electronic Control - 115 volt Dehumidifier HDN455E - No power
Check the fuse on the board. If the fuse is ok
check Zener Diode ZD2 on the board to see if its shorted.
If it's shorted replace.
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
