Question about Maytag Dishwashers
Maytag modle number MD87609AWS1 for some reason everything in the top pull out try isnt getting clean. thanks
Posted by tompack on
Robin Bonathan
  • 699 Answers
Your top arm is not rotating.
Take off the arm and check for blockages in the little jets along the edge.(rice is the worst culprit)
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 13, 2011
Modl wgd5100vq0
The number one reason for your issue would be a faulty stuck door switch. Does the black lever retract out when the door is opened, and can you press it in and hear a click when pushed in or released out? Best to have the door switch checked. Door switch part# 340617.
Apr 16, 2014 | Whirlpool Dryers
Hi. How do you get to the lid switch on a Maytag
You must remove the rear control panel housing...
Remove some clips - and then remove the basin surround.
Here is a video that will help you out without having to type out the entire instructions. It is a general instructional that covers just about all the manufacturers.
Thanks for using FixYa!!
Aug 05, 2009 | Maytag MTW5900TW Top Load Washer
MAYTAG QUIET PLUS II DRYER IS SQUEAKING
It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
Dec 25, 2012 | Dryers
I am trying to find out the cubic feet for my maytag heavy duty top loader washer model number LAT870588E
see this link to see the answer, I KNOW the model number isnt the same as yours but having been in the appliance biz for over 30 years i know both are the same capacity and only the features are differenthttp://wiki.answers.com/Q/What_is_the_cu_ft_capacity_of_a_Maytag_washing_machine_LAT8434AAE
Jul 18, 2011 | Maytag LAT2600A Top Load Washer
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Does anyone have the schematic for LCD control
Tom,
I don’t believe you will find a schematic for the control board. I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board? I got Maytag to send me one.
Saw this on e-bay
NEW - Maytag Washer LCD Control # 25001189
Good luck … Rich
Oct 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Glasses Get Dirtier in our Maytag MDBH950AWB Dishwasher
Sounds like you have either a calcium build up or are using to much detergent. more is not always better. if you have a calcium problem you may need to run a cleaner called dishwasher magic through your dishwasher. it comes in a 12oz bottle and can be bought at sears online the part number is wx10x10200. the other thing you can try is running vinegar in a cup facing right side up on the top rack through the dishwasher to see if it helps clean anything out. if not then the dishwasher magic may be the only way to go.
Dec 29, 2008 | Maytag DWU9962 Dishwasher
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Dishwashers Logo
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
