Question about Whirlpool Duet GHW9150P Front Load Washer
Sounds like a freight train when it spins - Whirlpool Duet GHW9150P Front Load Washer
Posted by ajsantoro on
john_cross
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
It is necessary to start with ensuring the machine is stable- it sounds as if yours might not be. Out of balance is a common problem with both front and top loaders!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Posted on Feb 13, 2011
There is loud noise at rear of machine when in the spin cycle llike a bearing dragging or such. But the tub spins easily??
could be the bearing. does it sound like a freight train when the machine is in spin cycle. if your machine is still under warranty or contract, call it in for service. if its not, then you might want to think about purchasing a new machine.
Jul 16, 2011 | Maytag Neptune MAH6500A Front Load Washer
Hi y'all! I recently aquired set of Neptune W&D. Washer is a TL and has 2 problems: 1. When washer goes into the spin mode, it sounds like a freight train going by. VERY LOUD...like maybe the...
Them are junk...Lol sorry but yes in the back where the pulley is there is a bearing and you have to replace the whole thing a 500$ part
Mar 13, 2011 | Washing Machines
When the washer spin it has a load noise, it sounds like a plane is comming down. I have a duet sport whirlpool washer
the bearing probably went bad, thats the sound it makes, may even sound like a freight train at times.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Final spin loud noise out of balance??
sounds like your bearing is shot
is this a fridgedair?
does it sound like a 747 or freight train?
if yes might as well throw it away
I would say your looking at about 5-6 hundred dollars to repair
you will need the basket and outer tub
the reason is your bearing is compressed from the factory in your outer tub and your basket shaft goes through the bearing
and usually gets eaten up by the bearing
Feb 11, 2010 | Kenmore 43142 Front Load Washer
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
I have a piece of **** duet washing machine. It suddenly stopped spinning. I knew this because the tell tale sound of a freight train in my laundry room wasn't there. I did take off the back and notice the belt was off of the pulley in the back. I got dirty, but I fixed the belt. It does spin now. Try the belt!
If I could only figure out why it it SO loud!
Nov 10, 2008 | LG Washing Machines
Maytag neptune MAH4000AWW Very loud noise when spinning
I found this on line ... 6/15/09 . Does your Maytag Neptune front loader sound like a runaway freight train when it is in high speed spin cycle? 2. Is your Neptune getting so loud that you cannot be in the same room while it is spinning your clothes? It sounds like your bearings may need some attention if you answered YES to the questions See www.neptunebearing.com ... Frank [email protected]
Sep 08, 2008 | Washing Machines
GE Washer WPSR3100W0WW roars like a freight train in spin cycle
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
Jul 03, 2008 | GE Profile WPSR3120WWW
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
