Xtreme Sound WMS336 CD Player Logo
Question about Xtreme Sound WMS336 CD Player
Xtreme Sound WMS336 CD PLAYER NO SOUND CAN YOU HELP ME THANKS
Posted by elyhigh on
Anonymous
    New Friend:
Im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
Posted on Jun 25, 2012
2 Related Answers
Anonymous
SOURCE: Xtreme Sound WMS303 CD Player
depress dsp button until clock flashes press volume up for hour,press volume down for minutes.
Posted on Sep 25, 2008
Anonymous
  • 130 Answers
SOURCE: no sound Xtreme Sound WMS336 Car CD Player
check your ground wire
Posted on Mar 01, 2009
The screen is blank what do i do...
I would throw it away and buy a new radio. Not trying to be harsh but it is a cheap product and not worth repairing.
Need a user manual
This is the only manual available for your device ->
http://www.barinas.com/AN-Xtreme%20Man.pdf
Note:
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
I was installing and the sound just stoped
sounds like u poped the sound relay in the player its self
SUBS NOT PLAYING THROUGH AMP
There is an otion to turn sub output on/off in the "audio menu". Hit " in lower left to turn sub out put on.
4answers
User manual
ian I need a valid email so I can email you the manual
2answers
2004 Toyota Corolla totalled and will not eject CD, Battery damaged
I'm simply going to pay the library $8 for the CD and be done with it.
Thanks for your interest!
Xtreme Sound WMS336 wont turn off
My WMS336 turns off only when I hold down the power button for a few seconds.
Faceplate removal
it is at the top if the faceplate when you push the button to flip it down in the middle top on the back is a big button push it down and slide it off.
1helpful
Cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Top Xtreme Sound Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
