Question about Delta Luv Delta - Baby Products 5-in-1 Crib
I am converting my daughter's Jordan 5 in 1 crib to a full size bed but where do I get the side rails from? I tried calling the phone number on the bed for customer service but it doesn't seem to work. Please help.
Posted by shajev2 on
5 Related Answers
Anonymous
SOURCE: Finding full sz bed rails 4 my Simplicity Ellis Convertible Crib
i think i have a solution to your problem. I too have been looking for simplicity bed rails but in honey to convert to a full. I found sears.ca and they carry the rails in every color but there version of the ellis crib is called the sydney 4 in 1. It is the same exact crib so I am purchasing the rails myself. If they do not end up fitting then just send them back. Sometimes canada have the same things as us but they are named different I know I live 15 min away from the canadian border. Hope this helps.
Posted on Feb 08, 2009
Anonymous
  • 189 Answers
SOURCE: bed rails
Here's a link to Delta Enterprises. If you click on the 'Customer Service' link they have an email and a customer service phone number listed. Hopefully you'll get some satisfaction and they can point you in the right direction.
http://www.deltaenterprise.com/product_overview.asp
Posted on Jan 05, 2008
Anonymous
SOURCE: Converting Simmons Crib 'n' More to a full size bed
You can call Simmons Customer support at 1-800-218-2741 and order the rails - they are $79.99 which includes shipping. I just did so yesterday. I had the same problem. I purchased this crib 5 years ago and now need the bed rails to convert to a full bed. You cal also email them at [email protected]. Shipping takes about 2-3 weeks.
Posted on Jan 16, 2008
Anonymous
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
Anonymous
SOURCE: conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
Posted on Jan 20, 2009
4helpful
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 • Baby Gear
16helpful
2answers
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
15helpful
4answers
Simplicity bed rails to convert to full size bed
we are having the same problem. My husband found this number online that another user said she used. I guess it took her months to find it because with the company being out of business the 800 number that came with the crib isn't working. I've yet to call he just called me with it. the company is out of canada and is said to have the rails or able to get the rails. Its Else Graco, you need your model number and color. 1800-667-8184.
3answers
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
39helpful
4answers
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at [email protected]
Feb 21, 2009 • Baby Gear
2helpful
2answers
Conversion instructions from crib to full size bed
Good Luck
2helpful
1helpful
5answers
Bed rails
24helpful
4answers
Delta Luv Delta - Baby Products 5-in-1 Crib Logo
Top Delta Luv Baby Gear Experts
john h
ray gallant
Tom Chichester
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
