Question about Cooper Industries Cooper Wiring 274W Switch and Outlet
Okay, I have the same problem... It is a cooper combination switch. There are two black wires that are coming out of the back . the instructions don't mention them at all. I am installing a new outlet and want to attach a new light to it. I want this in the bathroom, and I thought GFCI was the way to go. Why do they not include a complete wiring guide FOR THE DEVICE IN THE BOX?>???? I get the whole white wire to silver screw thing, but wtf are the two black wires coming out of the device for??? Do I attach the light to the load connections??? I need help.
Ok you have GFCI combination switch-plug.
Wires coming out of back of device are connected to "Load" wires.
Load are the black and white wires that go to fan, light, motor.
The black and white wires coming from circuit breaker connect to terminals marked "Line"
Look at back of device for markings.
Black wire from breaker goes to brass screw, white wire goes to silver screw.
There is one more set of screws on device. Device usually arrives with tape over these two screws.
This is what those screws are for: If you are working in a junction box, then three cables enter box.
One cable is for Line wires from breaker box.
Second cable goes to Load (light-fan-motor) that is controlled by switch.
Third cable goes forward to another switch or outlet >> and those wires connect to last set of screws on combo device. Black to brass and white to silver.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 17, 2011
6ya staff
SOURCE:
Wiring instructions for Cooper TR7730 combination wiring device
Hi Dave,
Great description, but you never mentioned what you are
using the switch for. I can explain in detail, but I need to
know if the switch load is coming from the same cable or
an additional one.
Dec 18, 2013 | Cooper Wiring Devices Electrical Supplies
Trying to wire switch and plug combination where the switch will turn off the plug
Black wire to brass connection on switch. White wire to silver connector on receptacle. Add a wire from the silver side of switch to the brass side of the receptacle. When switch is on current flows through to it to receptacle then out white when something is connected to the receptacle.
Nov 19, 2013 | Cooper Wiring Devices Combination Switch &...
Leviton 5226 want pilot to be on when switch is on. only white, black and ground come to box
If the white wire was previously used as a switch leg then it is not possible to use the device per code requirements.
Oct 15, 2013 | Cooper Wiring Devices ACE AC-DC...
Replacing a switch outlet combination with a switch GFCI outlet combination and there is only one cable in the box (14/3)
If it worked before, it should be a wire to wire replacement. You are replacing a regular switch/outlet with another switch/outlet which just happens to be a GFI outlet.
Wire the old switch wires to the new switch and the old outlet wires to the new outlet.
Cut the breaker/s off first !!
Sep 25, 2017 | Cooper Industries Electrical Supplies
My exsitting switch has two black wires connected to side of switch. a red and black coming from the back into wall. and a cooper wire on other side. this cooper wireing device comes with two black...
Ok so I gotta ask you are you saying that your existing switch has in total three black wires, a red wire, and a bare copper wire? If so then it sounds like the existing switch is a multifunction switch, meaning it works more than one fixture. If it had two black wires and one red wire then you more than likely have a three way switch, meaning the one fixture can be controlled from two different switches but either way the new switch will not work if it only has two blacks coming from it and your best bet is buy a meter and find out what is hot and what is not and go from there
Nov 19, 2017 | Cooper Wiring Devices Motion Sensing...
I have a light switch like this, I have 2 black wires and 2 white wires only. THe house was built in the 60's, I found I black wire that is constantly hot, how do I wire up the plug,light switch so...
Bit more information is needed.
Wire color is not as important as knowing what wire is for.
Knowing Hot black hot wire is good step.
Next, see if box has neutral wires. Neutrals are usually white wires that are twisted together and covered with wire nut. Test black hot to each white wire to find neutral.
If box does not have neutrals, then this device cannot be wired to code.
Other black wire probably goes to light.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Cooper Industries Cooper Wiring 274W...
Cooper TR274 common feed Single Pole Switch w/ grounding receptacle I have power at the receptacle but the switch does not work the light I wired in as the load. The hot lead feeds both switch and outlet...
Normally a socket needs both black power in and white ground out.
Normally a switch only needs the black power in and black power out to the device.
With a switch, the white return from the device goes directly to the white out, with a wire nut.
So you have a good reason to be a little confused with a switch and socket combination.
Normally I use an ohmmeter to figure out all the screws on a device like this first. But now that you have already connected some wires, you can probably just use a neon test light.
I think you are probably correct that the power is easy.
So put a neon test light with one lead on the white ground that came with the black power, and see which screw changes as you throw the switch.
If you don't get anything, then try directly from the white to black.
The screws should have some color coding. Brass for black, and chrome for white. There are often 2 black power screws because one is input and the other is for piggy backing off to the next device. There should be 2 white screws, one for the outlet and one back from the device. But there has to be another out from the switch to the device. I normally wire that in black as well. But hard to say what color this combination would use.
Jul 26, 2011 | Cooper Wiring Devices 274V-BOX DECORATOR...
Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
Cooper Industries Cooper Wiring 274W Switch and Outlet Logo
405 people viewed this question
Top Cooper Industries Electrical Supplies Experts
Gene Haynes
john h
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
