Look for tv code or codes for a isis 42" tv so i
Posted by pgoldingpaul on
Skiffle2009
    New Friend:
0338
Posted on Nov 13, 2011
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
Dec 27, 2015 | Alcatel Cell Phones
I Have a Bush tv.n8196ra012174.product name-LT42MICFA and cannot use the volume control on my virgin media remote,so have to use the tv remote for volume and the virgin media remote to change channels.the...
you can download the code from www.fitness.manualsonline.com or www. remotecodelist.com
2'= clean the contacts batteries very well
3= retight the spring contacts batteries with pliers for better contacts
4= open the r. control for clean the keypads switchs, for dirty, oxide, etc. in order to send the GOOD signal infrared to the receiver.
5= if the problem persist you must go to the repair shop TV for fix it or replace.
God bless you
Jul 14, 2012 | Televison & Video
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Mar 11, 2009 | Televison & Video
03223 tlu-Polaroid remote control codes for virgin TV
I just found it its 0008 I had to do it twice but it worked!!!!
Dec 27, 2008 | Polaroid 1720-7 Remote Control
Orion tv need codes for remote control.
I need help with remote control rca r5464 for orion tv
Dec 19, 2008 | Orion1934 19" TV
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Nov 07, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
