Question about Maxtor Hard Drive
Hello! my device is a maxtor portable storage device PN:9NX2A4-500 SN:2HB18R9R. It has been self-formated somehow and is not traceable by any laptop or desktop I have tried. Is there any kind of free software that solves this problem? What is there to be done so that I can use my device again? Thank you in advance. M.
Posted by marios_chort on
Eljo Morpurgo
    Sergeant:
  • 201 Answers
Ok install minitool partitioner free and format the hd to fat32
http://www.minitool-partitionrecovery.com/download.html
Posted on Feb 13, 2011
Valentin Volonikhin
  • 43 Answers
If it just been formatted and still works and in case you didn't wrote on it anything since the format,the only thing you can do it try to recover the files from the drive, you probably can forget about the OS. There are 2 good apps out there:
  • Recuva - A freeware app, does the job fairly.
  • File Scavenger - For 50$, if you really need those files.
Good luck...
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
Dec 23, 2017 | Maxtor Computers & Internet
Please tell me when this Maxtor 500 gig ext. hard drive was manufactured PN 9NT2A4-500 SN 2HA1FE6H Thank You !
hi
usually drives come with 3-5 year warranty .. USB external drives in todays standards are backed up with 5 years typically. i suggest you go to the link below, get in contact with Seagate (Maxtor) and have them tell you when it was made.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=212667&NewLang=en
Jan 09, 2011 | Computers & Internet
My laptop doesnot recognize my 250 GB Maxtor Basic Portable Storage unit . İt did no include a driver disc when I bought it. I thought that it was a plug and play one. My laptop asks for a driver...
Dear uralorhan,
Do not worry! just try to see your device manager,
START>My Computer>Right click for Propeties>choose HARDWARE tabs and pick the DEVICE MANAGER box.
When you saw the yellow mark USB device (Your MAXTOR should connected first), right click on it and choose UNINSTALL... then Confirm by answer YES.
Then go up to the device manager tool bar and click on SCAN FOR HARDWARE CHANGES.. Wait ..! and there... you should see the windows installed and prepare your MAXTOR to be ready for use..
GoodLucK!
Best Regards,
bionic23
Mar 18, 2010 | Acer Computers & Internet
Computer stopped being able to read external Maxtor hard drive. 640GB PN:9NZ2DG-500 SN:2HBADBDS. How do I retrieve data
Check the USB port and/or the cable, check if windows can detect your device. If windows can detect but can't read data perform a format or delete the partition and then use any file or partition recovery software you want to use. They will automatically rebuild partition table and MBR according to your need. If windows can't detect, unplug your device, uninstall the driver from the device manager, restart your pc, plug your device again and see windows will automatically install the device.
Dec 31, 2009 | Computers & Internet
Restore factory settings on maxtor basics external storage 1000gb
What do you mean by factory settings. From the factory, the drive came just formatted with no data on it. If you want that then format the drive in WIndows. My Computer->Select the drive that is Maxtor, right click it and in the box that opens format is one of the options. Select and follow instructions.
Nov 16, 2009 | Maxtor Hard Drive
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Hard Drive Logo
178 people viewed this question
Top Maxtor Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Lucky
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
