Question about Whirlpool Duet GHW9150P Front Load Washer
Where is the drain pump filter located? - Whirlpool Duet GHW9150P Front Load Washer
Anonymous
Hi, the filter is normally located on the front of the machine on the bottom right or left behind a panel that you have to pry off gently.
Hope this helps.
Posted on Feb 13, 2011
Where is drain filter located
Hello Jack Flannery - Generally speaking, the drain filter is located inside the tub to the pump hose. To access the drain filter it is require removing the hose from the pump.
Feb 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is code F 02
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(Actual drain filter location and procedure below)
• If the above does not correct the problem replace the pump
How to Check your drain pump filter for foreign objects:
Most likely, this issue will be the cause of a clogged drain filter. Use my procedure below to help locate and clean this filter.
First, you will need to unplug your unit and shut off the rear water faucets that feed the unit.The pump has a clean out filter located at the front, behind the lower section of the front panel, that allows for the removal of large objects that may have passed from the basket. You will need to remove the front panel to access this large object filter device. Now, Once you have located the drain filter cap; Push twits and pull out the filter cap that is visible. Clear out any debris and wipe the filter and the surrounding area with a mild detergent. If needed, wear gloves and use vinegar or bleach to remove odors, mold and mildew. Rinse the parts completely, if possible. Next; Remove the drain hose and clean it with a mild detergent or warm water. If necessary, again use vinegar or bleach to remove odors and mildew. Completely purge this hose. Once the drain hose has been purged, Reconnect the drain hose and filter. Next; Place the front panel back on the unit. Reconnect the inlet hoses and plug in the unit and turn it back on for a test run. If the cleansing dose not produce positive results, replace the drain pump.
Click here to access service manual for your unit. The actual component access procedures dealing with this issue will be on page 3-10 in the manual provided under the title"PUMP MOTOR". Front door and panel removal procedures are also described in this manual. This will start on page 4-1. Foucuse on pages 4-3 and 4-4 for front panel removal to access the drain pump and filter assembly.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
MY AMANA WASHER WILL NOT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Dec 03, 2009 | Amana Washing Machines
Altus washing machine wont drain
2. Water Pump
3. Drain Filter
Nov 26, 2009 | Tecnik TKL9260 Front Load Washer
My Kenmore washer is spinning but not draining. What should I do ?
2. Water Pump
3. Drain Filter
Oct 27, 2009 | Kenmore 44102 Front Load Washer
Machine not emptying completely
2. Water Pump
3. Drain Filter
Oct 23, 2009 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
