Question about Sony Playstation 3 (PS3) Console
My ps 3 is coming up everytime i power it up formatting
Posted by emmsy06 on
Leon Robinson
    Master:
  • 747 Answers
Unplug ps3 for a few min. then restart after pluged in.
Posted on Feb 13, 2011
Well everytime we hook up the HDMI for the playstation 3 to the tv it says invalid format how do i fix this
You must make sure your playstation and your TV set are both set for the same video format (1080p, 1080i, 720p, etc.).
You can either go through all your HDTV formats until it synchs up (give each a good 20 seconds or so before moving on), or you can open the display menu for your PS/3 using a different video connection to your set (i.e. composite), setting both to match, then switching them to HDMI.
Feb 15, 2011 | Televison & Video
Everytime I turn on mu playstation 3, no picture comes out in TV.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Try using HDMI cables and AV cables.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
Red screen
just replace it because i had the same problem
Apr 03, 2010 | Sony PlayStation 2 (PS2) Console
Hard Disk is corrupted, would rather not reformat.
This is to do a factory hard reset on PS 3 all files and systems settings will be deleted and restored back to factory this should hopefully solve your hard drive a problem. depending on the system reformat clould take 3 1/2 hours do a full format as to clear
Faulty memory
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
What the h*ll is a formating disc for ps2?
Format disc is what cleans the lenses, you might have dust on the lens and it can't read the disc. you can go to Wal-mart and buy it for $15, its the one thats for PS, PS2, XBox on the Gaming/electronic side. So everytime that happens again, just pop in the disc and it works again!
Jun 14, 2009 | Sony PlayStation 2 (PS2) Console
Looking for a format disk for playstation 2
hope this helps
Feb 18, 2009 | Sony PlayStation 2 (PS2) Console
I'm getting an invalid format on my hdmi inputs when i hook up my ps3. It's wierd because it works on my viszo, but not on my new westinghouse or my samsung.
If you accidentally set your PS 3 for 1080p resolution, when the TV can only support 720p, you get a black screen. The Westinghouse TV I used displayed a message that said "invalid format." To reset the PS 3 to the standard AV format, you shut the PS 3 off. Then you hold the PS 3’s power button down for about 10 seconds. It will reset to standard video
Dec 27, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Saving problems
you must have different playstations that have different formats when they were made. when you go to the store to buy a memory card, compare you ps system number with the number that matches the memory card on the package of the memory card.
Apr 04, 2008 | Sony PlayStation (PS) Console
Ps2 memory card
My memory card has been doing that too. It's either your memory card has gone bad or your ps2 memory card slots is fucked up
Feb 16, 2008 | Sony PlayStation 2 (PS2) Console
SYSTEM ERROR
Your solution depends on if system remain always in error status or it become usual after error message. First you should do hard formatting by removing sim and mmc then pressing four keys i.e. *,3,green send key and power switch simenteniously. Phone will get formatted and problem will be solved. If it doesn't work then we can say that there must be system file error. It can be resolved only by special tools like JAF or UFS.
Jan 02, 2008 | Nokia 7610
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
