Aunsoft Video Converter helps you convert between various formats. It is the...
Normal
0
7.8 磅
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:普通表格;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
<p><span>There is no
other one than iPad can be more perfect for you to watch video on the go, the
bigger iPad might be awkward for you to hold in some position, but 90-degree
angle to use iPad from your lap is the position you'll ever found comfortable
to watch video on iPad, bed or sofa will be also be ideal.</span><br />
<p><span>A pity
that the NEW Apple iPad still can only play back H.264 MPEG4 (.mp4), mov, m4v
Video files, so if you download flv video files from online video-sharing sites
or have camera HD videos like AVCHD VIDEO(.M2TS, .MTS), even common Video files
like AVI WMV MPEG that want to play Movie on iPad, you must need to <b><span><a href="http://www.video-to-ipad.net/guides/convert-video-to-ipad.html"><span>Convert Video to iPad</span><b> </b></a></span></b>compatible
formats.</span><br />
<p><b><span>Why We Need a Video to
iPad Converter?<span> </span></span></b><br />
<b><span>However, if we want to watch movies or listen music on ipad, we need use
a video to ipad converter suite to help us.</span></b><b><span><a href="http://www.video-to-ipad.net/">Video
to iPad Converter</a> </span></b><b><span>Suite</span></b><span> is all-in-one iPad Video
Converter package for iPad, including two iPad tools: Video to iPad Converter
& DVD to iPad Converter, to convert DVD movies and videos to iPad supported
video format. With iPad Video Converter Suite, we can easily convert all our
DVD movies and videos to iPad and enjoy it on-the-go. So with this single
package we can convert both DVDs and video file media to iPad video and iPad
movie formats.</span><br />
<p><b><span>Preparation:</span></b><span> Download Video to iPad
Converter and run the program, Click Video Converter button.</span><br />
<p><b><span>Step 1: Add Video to iPad Video
Converter</span></b><span></span><br />
<p><span>Click <b>"Open
file"</b> button to select and open the video file you wish to
convert. Video to iPad Converter supports most of the popular video formats, so
you can easily convert AVI to iPad, MKV to iPad, and even HD video formats like
AVCHD M2TS MTS to iPad format.</span><br />
<p><b><span>Step 2: Select iPad preset from output
format list</span></b><span></span><br />
<p><span>In the
Output video section of the interface, choose the right preset for your iPad
device in the <b>"Profile"</b> drop-down menu. There are
many options when you're converting your videos for your iPad. Obviously, the
better the quality, the larger the file size. Ultimately it's a personal
decision everyone has to make on what's more important: space on your iPad or
audio/video quality. Personally, I prefer to stick with the default profile
because the good quality video and audio are given. You just have to pick and
choose which profile you want to keep on your iPad. Play around and see which
results you like best.</span><br />
<p><b><span>Step 3: Start Conversion</span></b><span></span><br />
<p><span>After all
the necessary settings are ready, you can click <b>"Convert"</b>
button to start convert video to iPad. As soon as the conversion is completed,
you can click "Open" button to find out the generated files easily. And then
sync them to you iPad, with iTunes.</span><br />
