Question about Smeg A3-5 Gas Kitchen Range
We need to replace the hinges on our Smeg A3-5 main oven door but can't figure out how to do it. Thank you for your help.
Posted by the_cushways on
4 Related Answers
Anonymous
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
Anonymous
SOURCE: Smeg DUC08CSS Main oven not functioning
reset automatic clock
Posted on Mar 15, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
Anonymous
SOURCE: fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Posted on Feb 27, 2010
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
I have a Smeg A1-1 Cooker. The main oven door does not shut properley - it hangs open a bit and so lets out lots of heat?
you have to replace the door hinge's an easy fix but you have to strip the doors apart so a good time to clean.
Jul 13, 2009 | Smeg A1A.1 Gas Kitchen Range
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Fitting ne hinges on a smeg 90 oven door
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
The oven door won't close properly, it just hangs slackly about 2 cm from the seal. it's a smeg wall oven.
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door inwards.you should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Jul 11, 2008 | Smeg Kitchen Ranges
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Put back smeg oven door
http://www.smeg-service.co.uk/support/index.php?a=3
Here is a link to the pdf file that you can download from the internet for instructions about your door.
Just copy and paste the link into your browser window and click.
Jun 25, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
Smeg A3-5 Gas Kitchen Range Logo
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
