Question about Hampton Bay 24002 Ceiling Fan
Missing remote for a clarington ceiling fan model sku 507090 .serial number 8239271605. home number 450 969 2309
Posted by gbarbieri on
Anonymous
    New Friend:
    Problem Solver:
  • 14 Answers
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Posted on Feb 18, 2011
Rhine ceiling fan remote replacement
If it's an add-on remote then you can probably use any generic receiver & transmitter.
Oct 03, 2013 • Dryers
New home have a hunter fan with no remote receicer is a cp911OR were can a buy a new kit with remote
call hunter at this number: 1-888-830-1326
have the model number of the fan handy and explain to them your problem. in most cases they will be able to get you a replacement part or kit for what you are missing
We just bought a house with a beautifiul Hampton Bay ceiling fan, however the remote is missing. Consequently, we are unable to use the fan. Is there any way to determine if the fan is operational?
Try Home Depot. They sell Hampton Bay fans. They should have replacement remotes.
Here is one that Amazon sells. If you order oline, check to see if your model number is
what the remote will control. Also return policy of the seller if it doesnt work. May be easier
to go to Home Depot with a picture of the fan, or model number if you can locate it. Remember
that you will still have to figure out what settings to set the switches to that control the channel
the remote works on. It's do-able.
http://www.amazon.com/Hampton-Bay-Portable-Ceiling-Control/dp/B002L9SHJ4
1helpful
Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
2answers
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
3answers
Need remotes
In theory, they should. Try Hampton Bay first, and if not, check for aftermarket replacements. Those remotes are simple enough that there is no reason that they can't.
4helpful
6answers
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
2helpful
3answers
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Michael Thomas
Michael Thomas
Fahr Quad
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
