Dryers Logo
Question about Dryers
We have had a Hampton Bay Renaissance II model # 129857 installed for about 5 years. Suddenly, the light fixture popped, and a new light kit is needed-is it worth searching for a new light kit, or should we pursue the "lifetime Warranty" that Hampton Bay offers?
Posted by tkpollard7 on
Mark Berger
    Habit-Forming:
  • 23 Answers
We had a similar problem happen with our Hampton Bay Renaissance fan. It turns out that the warranty does not cover this by the way. The lifetime warranty you refer to is only on the fan motor. This is common with most fan manufacturers- just wanted to let you know about this because I think your interpretation of the warranty is wrong.
This fan is really hard to find and so are the parts for it. I would recommend trying to call Home Depot where you bought it or call the Hampton Bay customer support phone number. You're likely going to have to go through one of those mediums. I feel that the second thing (calling technical support for Hampton Bay) will probably connect you to Home Depot too because Hampton Bay is a house brand of Home Depot.
We were able to find the phone numbers we needed here:
https://hampton-ceilingfans.com/hampton-bay-ceiling-fan-reviews/hampton-bay-renaissance-ceiling-fan-light-fixture-popped/
Posted on Jan 15, 2023
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: hampton bay romano II 54 inch instructions
what information do you need - I may be able to help you.
Posted on Aug 22, 2007
Mike McWhinney
  • 537 Answers
SOURCE: this Hampton Bay light fan fixture eats Light Bulbs
Read the manual to find out which size bulbs (base size and wattage) you need.
If you did use the right type of bulb and it lasted only 2 weeks, take them back to the store where you boght them for a refund.
Mike
Posted on Jan 17, 2008
MI-gal
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
Anonymous
  • 25 Answers
SOURCE: trying to find light kit for Model 56-ANTm Flemish Brass
check the kit at home depot, get name and phone number of manufacturer and call them to see if they can supply the glass that you want.
Posted on Jan 15, 2009
Anonymous
  • 16 Answers
SOURCE: Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Posted on Jan 21, 2009
1helpful
2answers
How do I know if the problem with my Hampton Bay Windward II fan is with the ceiling or with the remote. It worked fine for years and now all of a sudden it is hardly ever responding to the remote?
Did you try changing the battery? Unlikely to be the fan, but it could be the receiver.
https://www.amazon.ca/Anderic-Replacement-CHQ7096T-Key-Thermostatic/dp/B06XFX1RW9
I have two Windward II fans. ONe of them has stopped ...
https://www.justanswer.com > electrical > 52wg3-two-w...
Jun. 3, 2011 - This is a problem with the remote receiver, located in the fan's canopy. ... the receiver that works with this Hampton Bay Windward II fan/light? 1 answer · Top answer: Jason : Hello. Thank you for asking your question on Just Answer... Jason : This is a ...
Hampton Bay Windward II fan suddenly stopped working. I ...
https://www.reddit.com > fixit > comments > hehdaa
Hampton Bay Windward II fan suddenly stopped working. I checked the DIP switches and have now replaced the remote (I had read that they sometimes just ...
Fan remote not working - Hampton Bay Fan & Ligthing co ...
https://www.bobvila.com > posts > 30120-fan-remote-n...
Jan. 25, 2005 - As far as getting the model/serial number off your unit, it's most likely on the base area where it attaches to the ceiling - meaning you'll have to pull ... .
Cannot find cameron ii plus single light fixture model 483 112
I agree with Home Depot, I haven't tried calling King of Fans before. I'll have to give that a whirl!
I also found this link below that has a replacement kit, they don't have the light kit though. Maybe you could ask them to add it:
https://remotecontrolplace.com/universal-remote-controls/where-can-i-find-parts-for-the-hampton-bay-cameron-ii-ceiling-fan/
We have the hapmton bay 52 in cameron II plus in chrome and blue neon fan. Is there a different light fixture that can be attached instead the neon light fixture? The fan still works great, but we dont...
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Can't find light kit to fit 52" Hampton Bay ceiling fan
I've found that Hampton Bay has it's own light kits, available only from them. The others (generic) aren't the same size. Hampton Bay fans are made exclusively for Home Depot. They are made by a few different manufacturers but only Home Depot sells them. I would have Home Depot customer service get a brochure for you so you can order what you need, if they don't stock it.
Trying to find light kit for Model 56-ANTm Flemish Brass
1helpful
2answers
Cameron II Plus
The wiring, concealed under the ceiling trim needs to be corrected; there will be at least three leads, one for the fan motor, another for the lights and a 3rd wire that is the neutral for both.
There should be an additional (4th) lead that is connected to the body of the fixture that will be green or green and yellow; this one is for safety and carries no current unless a fault in the lamp wiring or the motor occurs.
I believe that Hampton is a Home Depot brand name but don't depend on them for help.
Open Questions:
0answers
Lg dryer DLG1701W te1 and te2 codes blower thermostat keeps blowing as well Hello my lg dryer model number DLG1701W has been having issues for the past 3 days. Dryer finished a normal cycle and wouldn't start up again after swapping load of laundry out. When I tried starting it up again it was throwing a te1 code. Looked up the code on lg's website and tried doing a hard reset. Tried a few more times again and this time I was getting a te1 and a te2 code. Looked up the te2 code and decided to pull the machine out and inspect/clean the exhaust. Exhaust wasn't clean but air flow also wasn't restricted and the flaps on the outside of the house were on and in good shape. Hook the machine back up again and tried starting it again with attempting to reset again with no luck. I decided to pull the machine apart and test the thermistor with my fluke meter. found the thermistor on the exhaust side was reading but was all over the place. 13 ohms while in the machine. Down to 9 ohms when removed. After letting the thermistor sit for a little bit it was reading 11 ohms but was all over the place in that range between 11.08 to 11.96. Wasn't sure if that was normal or not so I decided to replace it. Tested the other thermostats while I was in there and found both thermostats on the gas range were reading normal but the thermostat on the exhaust side of the unit was faulty. Not reading at all. So I replaced the thermistor and the thermostat on the exhaust side. Button the machine back up and go to test but initally the same error codes were coming up te1 and te2. Finally after a few more attempts the dryer started. I had it set on a high temp 40 minute cycle. After about 10 minutes of it running though the barrel stopping turning and the gas range shut off. But it didn't throw any codes. The display continued to countdown and all the other light were working as if it was still running. Shut it off a few times and tried starting it back up and the same thing would happen. Countdown would display and countdown. All the lights would light up as if it was working but the barrel wasn't turning. And the gas range wasn't running. I walked away for a little bit to think about it (approximately 2 hours) when I came back to it, the machine was doing the same exact thing as what it would initially do. Click and display a te1 or a te2 code. I pulled the machine back apart again and currently still have it apart. The thermistor seems to be in a continuous 11.25 ohms range with the ohms dropping when touching the sensor it self. The thermostat that was just replaced has blown once again. Any insight on why this could be happening would be very much appreciated Update. Checked all the components again including the motor. Motor checked out good. Put everything back together again. Try it again a few times. This time everytime I tried it, the machine would start and run for a 4 to 5 seconds then shutdown and throw back the te1 and te2 code. Note: it never has both the te1 and te2 code at the same time. Each time it's tried it 1 or the other
Top Dryers Experts
Marvin
Marvin
David Shaub
