My Amtrol SF-20 is cycling wildly from 90 down to about 30. Water runs at low pressure then up for about 10-15 seconds then back down again for about 30 seconds. How do I clean/service the unit and replace air? The service tag says it is a 90psi unit.
Posted by stormyehitch on
Anonymous
  • 927 Answers
I can't find that model number on the Amtrol site, please check it.
Is this a water storage tank? With an air charge?
If so:
Remove the dust cap on the charging valve on top, Schrader valve, like a car tire.
Use a small tool to slightly depress the pin in the middle.
If water comes out, the tank should be replaced but adding air will help for a while.
If air comes out, you can pressurize.
Determine the pump turn on and turn off pressures using a good pressure gauge.
Turn on may be 30 psi, turn off should be around 50 psi, TYPICALLY.
Switch the pump off.
Open a valve and drain all pressure from the water system.
Get a tire pump and pump up the tank pressure through the top valve to 2 psi lower than the pressure that the pump turned on above. If the pump turned on at 30 psi, pump up to 28 psi.
Put system back in service.
Gary
Posted on Feb 13, 2011
  • Anonymous Feb 13, 2011
    I would like to add that there could be a pump problem, rather than a tank problem, but I don't know enough about your system.
    Gary
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
http://www.amazon.com/dp/B000BQSERE/?tag=waterheaterti-20
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
http://www.amazon.com/dp/B0060C7GFO/?tag=waterheaterti-20
Drain tank, and replace the air valve
http://www.amazon.com/dp/B000BQYKJK/?tag=waterheaterti-20
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 22, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
Feb 12, 2013 | Heating & Cooling
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
I have a Rudd furnace and air conditioner. The air conditioner is not working. The external air conditioning unit will start and run for 15-30 seconds and then shut-off. It tries to do this about every...
Hi, and no they are not related, but act like they are. If the outdoor unit starts, fan and all, we call this short cycling on its pressure switch. You have 2 pressure switch's, one for low pressure as its low on freon, or high pressure where its overheating and shutting off on its head pressure switch. Unplug it at the box near the unit. Take a garden hose and wash your coil out real good, but not to flatten the aluminum fins on the coil. You can also use a solution of detergent and water to spray the coil down before washing if you can, but you don't have to to find out if it is the high pressure switch. If it continues to short cycle, then you have developed a small leak and lost enough freon to cause this problem. You will need to have it charged and leak checked if they determine how large of a leak it is. I am pretty sure from the amount of time it starts and stops, its low on gas. When the unit starts, the compressor will start to pump causing it to go into a vac on the low side gauge. When running on a full charge, it will be on about 64 p.s.i. at 95 degrees outdoors. If is low on gas/freon, it will pull down to around 20 p.s.i. which is the factory set point for the low pressure switch to kick off. The gauge will then start to rise and in seconds start up and repeat this again. This is what yours is doing now. Try washing the coil first, and turn it on. If it continues to short cycle, you will have to get it charged. If its 10 or more years old, it will take the R-22 freon. If newer, it may be the 410-A. Either way you cant buy it. I hope I have been of help to you. Please let me know.
Sincerely,
Shastalaker7, a/c Contractor
Jun 06, 2011 | Ruud Heating & Cooling
Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
Mar 28, 2010 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
I have a large Amtrol water heater. I bought the system origianlly several years ago. Last year the bladder failed. Amtrol honored the lifetime warranty and provided a new one but I had to pay installation...
i would recommend getting a "superstor" tank,...(not messing with the amtrol again) is this run off of your boiler? if so, you'll like a "superstor", good luck, cracklin joe,........
Jan 04, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Gould 1/2hp submergible well pump cycles on and off constantly. low to no water pressure .The pressure switch remains in the closed position. Power to pump side of pressure switch good. pump runs 15...
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
I hope this may have helped,
Tom
Oct 10, 2009 | Plumbing
Kenmore Elite Calypso
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
john h
