Question about General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator
The light in our refrigerator does not work, we replaced it, and it still doesn't work. What else should we look at to solve this problem?
Posted by aleighton5 on
Tony Wisinski
    Master:
  • 385 Answers
The operating switch that turns the light on when you open the door may be the problem>
Posted on Feb 13, 2011
My samsung fridge keeps freezing. what can I do to stop this. It is only two years old. It has been a spasmodic problem from new.
Thai is common problem and has yet to be solved. Samsung came up with a drain clip, which serves as a heater and it seems to work. Otherwise they replace the evapor cover, which doesn’t work.
Aug 02, 2018 | Samsung Refrigerators
1998 buick century high mount brake light doesn't work, bulbs have been replaced
there is a seprate ground that mounts to the frame of your car near the light usualy in trunk in between the rear speakers locate and make shure the conection is good.if that dos not solve it on the pasengers side rear light check bulbs for detereated ends if thay are then replace.this shuold solve you problem
Jan 19, 2013 | 1998 Buick Century
Refrigerator light and temperature display not working
Check that the wires going to the temp. display has power on them, if "yes" change temp. display......
Lights the powre goes to a switch on the door frame that sends power to the light in refrid.
Dec 14, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Constant flashing lights
These lights flashing are an indicator that something is wrong with the unit. Once the problem is solved the following steps will reset the lights so that they stop flashing. If you don't believe there is an issue you can try these steps and it will reset if nothing is wrong.
1.) Turn the refrigerator and freezer to 0 this will cause them to turn off.
2.) Hold Super Freeze and Super Cool buttons down for 15 seconds.
3.) Return your freezer and refrigerator temperature settings back to what they were before you turned them all the way down.
If this doesn't stop the lights something is still wrong with your unit and it is informing you of this.
I hope this helps!
Oct 20, 2012 | Refrigerators
What would make refrigerator not run no lights or anything
There is a good chance that in the wall a wire may have come off the plug. I would try plugging the fridge in somewhere else to see what happens. If that doesn't solve it there must be a bad connection from the plug end to the frige. I would pull the back off of the frige and inspect for loose wires following the power cord into the fridge
Sep 06, 2012 | KitchenAid Refrigerators
Won't make ice
It probably still MAKES ice, it just doesn't dispense it. The ice drawer may be blocked. Remove the ice drawer, empty it, rinse it through with luke warm water - including all non electrical moving parts, dry thoroughly, replace, give the machine time to replenish the ice, should solve your problem. Assuming it is just that it is only that it is blocked.
Dec 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The icemaker is extremely slow in making ice. maybe 12 cubes a day. The water comes out very slow from the water dispenser. Any solutions?
yes, the solution is : replace the water filter. if that doesn't solve the problem then the water inlet valve needs to be replaced.
Jul 16, 2011 | Refrigerators
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
Door will open will not close
The door on a refrigerator is an important component to the over all functionality of the refrigerator. A simple refrigerator door repair can potentially save hundreds of dollars in energy every year.
Check the Hinges
A misaligned door hinge can release cold air from inside the refrigerator, causing it to run less efficiently. If the door doesn't shut evenly it could be a problem with a hinge. The easiest repair for this is to simply tighten the screws that hold the hinges. If this doesn't solve the problem try to see if the hinges are level. You may need to replace the hinges all together.
The Door Gasket
The rubber piece that circles the entire door serves a purpose more than just helping the door close quietly. It should form a seal that maintains the temperature inside the refrigerator. If the gasket is cracked or warped you will need to replace this. Find the model number for your refrigerator and you can find the right gasket. Some gaskets are simply put on with adhesives, others require clamps or screws.
The Light
If you have a faulty door switch, the light may stay on in your refrigerator. This wastes valuable energy. To check this simply find the switch and press on it with the door open. Sometimes a thorough cleaning of the switch can fix the problem.
By maintaining your refrigerator door and making the necessary repairs you can save yourself a lot of money in lost energy costs.
I hope this help in solving the problem....
May 08, 2011 | Frigidaire FRS26R4C Side by Side...
In the frig part their is 2 light bulbs1 doesn.t work at all the other flickers tried replacing it does the same it flickers
the bulb that does not work replace and the light sw mabe causing the flicker and if not you have a loose wire connection . mm
Sep 02, 2010 | Whirlpool Refrigerators
General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator Logo
Top General Refrigerators Experts
Vernon Taylor
Paul Bade
Arnie Burke
Arnie Burke
Are you a General Refrigerator Expert? Answer questions, earn points and help others
