Question about Garden
What is the location of the engine number of Toyota prius hybrid car? I can't find the engine number of my Toyota prius hybrid car inside the bonnet
Posted by vinkaushi on
5 Related Answers
Lovebytes
Dave Richardson
  • 10 Answers
SOURCE: 2001 Toyota Prius - A warning light with exclamation mark on a car appeared on the MultiVisual Display Unit
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
Posted on Aug 21, 2008
s60six
  • 328 Answers
SOURCE: toyota 2001 prius hybrid- warning signs
your owners manual should show all of the symbols and what they mean.I tried to get one to look at it but no luck...they should be in the manual though
Posted on Dec 15, 2008
Anonymous
  • 507 Answers
SOURCE: 2003 Toyota Prius Hybrid, Power Steering problem
I don't know about hybrids, but on most vechiles, you check power steering fluid with engine running.
Posted on Jun 23, 2009
Anonymous
  • 4793 Answers
SOURCE: Where's the bonnet/hood release lever for a 2003 VW Golf located?
you will find a black lever either on the right or left kick plate (that is the trim piece from the floor to the dash on the outer floor pan) inside the car, under the shelf, under the glovebox depending whether left or right hand drive.is is a bit dark to see it tucked up as it is.
Posted on Mar 10, 2010
Anonymous
  • 367 Answers
SOURCE: check hybrid system light came on on a 2010 prius.
It's a year old. Take it to the dealer immediately and have it repaired under warrantee. Don't wait too long or they might say further damage was caused because you didn't get it looked at immediately.
Posted on Mar 06, 2011
How to find heater core hoses location an replacement 2006 Toyota preuis hybrid motor 1.5
toyota sells them, cant find a dealer?
are you asking 2 questions? where are they and where to buy?
Feb 02, 2015 | 2006 Toyota Prius Hybrid
2007 prius master warning light, (!), VSC and engine light on
The problem may be the check engine light only, whenever it turns on the master warning light may also turn on, if there is an autozone or similar autoparts place close by you can go there and they can diagnose the check engine light using their scantool, then you can reply here to me with the code numbers and I can help, the code numbers are important so please write them down.
Apr 07, 2013 | 2007 Toyota Prius Hybrid
Toyota prius p3006
YOU EITHER REPLACE HYBRID BATTERY OR HYBRID BATTERY
COMPUTER
Nov 14, 2012 | 2001 Toyota Prius
I have a red triangle with ! inside it and red car with ! in the middle of it , so please i want to know this error in Toyota Prius 2008
This the hybrid master warning light, which means the system has detected a malfunction, there are many causes that turn the light on, there are about 24 computers involved, the best advise I can come up with is that you have the toyota dealer check this and diagnose it, this may also still be under the powertrain or hybrid vehicle warranty
Aug 21, 2011 | 2008 Toyota Prius
I have a 1998 NWH10 Toyota Prius. My problem on Start up.
Have both your battery and alternator inspected. Turn it on, disconnect your negative battery cable, if it dies, you need an alternator, if not, then you may want to test your battery for bad cells.
Feb 16, 2010 | Toyota Prius Cars & Trucks
Jun 23, 2009 | 2003 Toyota Prius
Need to know parts name
Velocity sensor or somtimes called speed sensor.   They communicate the transmission to the engine's computer so they know when to shift up or down on the gears.
Ps: don't break them. Good luck and hope this help's
Apr 09, 2009 | 2004 Toyota Prius
Engine light for hybrid system came on
Seems to be alot of this problem mentioned on this forum regarding prius warning lights.
Don't worry yet might just be a service reminder.
Google " 2005 prius warning light " the first page will show a link to toyotapartsandservice.com where you can find the owners manual that covers all the warning lights.
Feb 03, 2009 | 2003 Toyota Prius
Jul 28, 2008 | 2001 Toyota Prius
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
ray gallant
