My 15 year old Aiwa rceiver started shuting down recently after a minute or two on when i turn up the volume knob. It's connected also to soney TV and sony dvd player.
Posted by truewater99 on
David Dunn
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 13, 2011
Volume nob wont work
The contacts on the volume encoder are dirty. The only fix for it is to take it off of the board, open it up and clean the contacts. You need to be pretty handy with electronics in order to pull this off. I don't think you can find a replacement encoder any more. Sony bought Aiwa years ago, but doesn't really support the product with parts anymore.
Should i spray the inside of the volume knob to fix the volume?
You can try contact cleaner. Spray some in (with unit turned OFF) and move the knob up and down several times stop to stop. then try to see if it helped.
Need manual to set clock,etc
To set the clock: Press and hold the "Disp" button until the clock shows in the display window. Turn the Volume knob to turn the hour up or down Press the "Disp" button again Turn the Volume knob to turn the minutes up or down Press "Disp" again.
You can see and download the manual here: http://www.fixya.com/support/p200366-aiwa_cdc_x504mp_cd_player/manual-1149
1helpful
2answers
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Tv turns itself on and off
IC pin is dry in Micropro. IC
1helpful
Aiwa Colour Television Model TV-SX2150 KE - Audio Problem
i can solve ur prob by your self but u have to pay for that.
Why does the volume go all the way up when i put it to 15?
aiwa typical issue. loved my aiwa's sound hated the stereo. my volume control knob did the same thing and i had to order a new control.
please take time to rate,
good luck
Ryan
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Aiwa CDC Z117 volume dilemma
you probably try this move the nob in or out maybe it beetwenn 2 set in knob broken remove it turn the knob manualy good luck cheers
2helpful
5answers
Volume knob
Hi Your Problem need an expert Technician, this Aiwa stereo has the digital type volume control that gives pulses to the cpu to make volume up / Down. Solution to be fixed by a technician: - Remove the volume from the front board, disassemble it and clean the conductive parts inside it then reassemble back and check. Good Luck Toufic G. Malek
 Grubhead
Grubhead
