Question about Acer (91.16848.010) Video Capture
No acer capture device found on your system - Acer (91.16848.010) Video Capture
Posted by milkyroad200 on
Archaeology
    President:
  • 662 Answers
Your driver has been disabled. To re-enable it (in WinXP)
START > Control Panel > System > Hardware (tab) > Device Manager (button)
Find your device - Right-Click on it > Left-Click on the Enable (button),
or after Right-click - instead of "Enable" you can select "Troubleshoot"
If you're running WinVista or Win7, these WinXP instructions may (or may not) be close to what
you need...
Posted on Feb 13, 2011
1 Related Answer
SOURCE: No Acer video capture device was detected on your
you have to use the driver cd which came along with your device and install them and this will install the driver for your capture device and your hardware will be detected.
thanks
Posted on Oct 07, 2010
I need to install this camera but i dont have the disc
go to control panel/system security/system/device manager. on the top scan driver click it... if you see an icon camera with yellow sign (like this ?) click it and install update online... automatic online downloading... step by step ...
thank you...
Jan 19, 2011 | A4tech PK-7ma Flexi Webcam
I have no idea how to open the WEBCAM on my 4820TG model Laptop
I found that everything depends on the order in which you enable the various devices.
It seems it has to be in this order
1. Devices - Acer Crystal Eye Webcam
2. Devices - Microphone Realtek
3. Capture - Capture Audio
4. Start Capture
5. See self in recording and recoil in horror and despair. :-)
Nov 14, 2010 | Computers & Internet
No Acer video capture device was detected on your system.
thanks
Oct 07, 2010 | Acer (91.16848.010) Video Capture
When i try to start my webcam it tell me there are no acer video capture device found how do i fix this
check for drivers, update the driver , go to manage devices and check for update driver,
Sep 06, 2010 | Acer Computers & Internet
Where can I find the integrated web cam on my emachine e725 laptop?
Select models of Acer netbooks also ship with a program "Acer Crystal EyeWebcam". This program will enable the webcam immediately after startup and can be used to test the webcam acnd take pictures.To test the webcam under Windows XP, please follow these steps:Go to Start, All Programs, then Windows Movie Maker.On the left side, click the link for Capture from video device.Select Next throughout the set up, making any file name changes or setting changes if desired.On the Capture Video screen, click on the Start Capture button You will see the video on the right with a time count up When you are done click the Finish button Click the play button on the video clip, or drag the clip to the Storyboard below.
To test the webcam under Windows Vista, please follow these steps:
  1. Go to Start and then All Programs.
  2. Click on the Acer Crystal Eye webcam folder
  3. Click on the Acer Crystal Eye webcam application
  4. The webcam should automatically turn on and display an image.
If the webcam is not being seen after following the above steps, it may be necessary to uninstall and reinstall the driver.
  1. Go to Start, Control Panel
  2. Double Click on System
  3. Click the Hardware tab and press the button for Device Manager
  4. Click the + next to "Imaging devices"
  5. Click to select any component listed under Imaging devices and then right click the component and select Uninstall.
    Repeat this if there are multiple components listed.
  6. Reboot the system to redetect the components and reinstall the drivers.
Mar 02, 2010 | E-Machines M2350 Notebook
Integrated Webcam doesn't work (E620)
dear you tried everything thats good, now restart the laptop and go to bios and enable the camera from bios.
it worked for me hope it will help you
Mar 23, 2009 | eMachines M6811 Notebook
To capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
Feb 07, 2009 | Acer Aspire 6920 Notebook PC
I cant find the webcam icon
Use ACER Arcade application.
From User manual:
"Acer Arcade allows you to capture and record video clips from other external
devices, such as a DVD player or camcorder.
Click Capture Device on the video page and then select the source you are using
for your video input. There is a choice between "S-video" and "Composite."
To capture a video clip, you then need to click the red record button in the
onscreen controls.
The destination folder can be set from the "Settings" menu.
Clicking on Advanced and selecting Settings allows you to set the quality of the
video captured. You can choose from "Good," "Better" or "Best." Selecting a
higher quality results in a larger file when capturing video clips.
Snapshot
Snapshot mode is available in Cinema, Video and TV modes. This function can
be used to capture the onscreen image at any time."
Jan 05, 2009 | Acer Aspire 5610-4648 Notebook
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Problem with the camera
Try to uninstall the drivers for cam. and reinstall the fresh copy. it will extract all the files and the icon will display on desktop. if u double click. it will open the cam. and the image will be black. Right click on the blank picture and select capture image. It will work
Dec 19, 2007 | Acer Aspire 5100 Notebook
Televison & Video Logo
556 people viewed this question
Top Acer Televison & Video Experts
Marvin
Marvin
Paul Bade
Harrie
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
