Question about Emerson Televison & Video
Emerson tv DVD says disk error - Emerson Televison & Video
jasbo
  • 2,239 Answers
Clean the disk and use a lens cleaning disk for the lens. if it spind but won't read, you need to replace the optical pickup. if you don't hear the disk spin, you have a bad motor and still need to replace the optical pickup.
Posted on Feb 13, 2011
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
Nov 14, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Disc error when I try to record
get a dvd cleaning disk might solve your problem
Aug 24, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD disk will not stay in the unit
USE DVD LENCE CLEANER, ITS AVAILABLE IN MARKET
Mar 30, 2008 | Emerson EWL20D6 Television
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
No playback
The dvd player does not recognize discs above 2x. I contacted Emerson, they have a software upgrade they will send you for free, but you have to ask for it. I think it gives the player the ability to read up to 8x.
Aug 15, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Emerson sb350 parentel control
Try these codes 0000, 1234, 000000,123456. If these codes above doesn't work, check the manual. good luck
Aug 30, 2006 | Emerson SB350 13 in. TV/DVD Combo
Televison & Video Logo
Top Emerson Televison & Video Experts
Mike
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
