Question about Sharp LC-32SH12U TV
Sharp model LC-32SH12U - 2 hdmi ports - whenever anything is plugged into them - ps3, apple (MBP, via cable, blu-ray player) they just show a green screen. We checked other hdtv's and it is just this tv. Trying to figure out what the problem is considering it can't just be that 2 separate hdmi ports are bad.
Posted by c5831690 on
Anonymous
    New Friend:
I don't have a solution but starting 2 weeks ago I have the exact same problem. Test different devices and cables and it points back to the TV. Anybody have a solution?
Posted on Feb 23, 2011
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
Sharp Aquos LC42d64u has blurry picture...
Is it slow and blurry? if yes then return it to warranty immediately. The video processing circuits are malfunctioning and the repair cost is prohibitive if you must pay for it on your own.
I hope it is still under warranty. So, do not delay getting it into the Sharp Authorized facility or back to the retailer you purchased it from.
The connection cable you use could have something to do with it, but is should work on all formats. The best for reliability and absence of blocking is just analog composite - but that is also the lowest picture resolution. S-video is okey too, but it is analog as well. Component is the highest grade; going to hdmi is just another way of receiving the signal - I don't think it will effect the error correction problem in any way. My opinion.
Goodluck..
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp Aquos LC-40E67UN is plugged into a Sony Blu Ray home theatre system BDV-IZ1000W. It is hooked up with an HDMI cable. I get sound but no picture on the TV. If I unplug and replug the HDMI cable...
Wow it seems as though you've pretty much done all of the applicable troubleshooting for this issue. The only other thing I can advise in this case is to consider purchasing a SD card. Some Blu Ray players require a little extra memory to function properly so they come with an SD card slot. Of course no one tells you this when you buy the player but it may be the solution to your problem.
Jul 18, 2011 | Sharp Televison & Video
Flickering screen (LC-52SB55u) with HDMI cable input from Sharp Aquos Blue Ray. HDMI working well from other inputs
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Nov 28, 2010 | Sharp LC52SB55U LCD TV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Does a 2002 Hitachi 61' 61swx10b have a pixel count ?
you have to tell your blu ray player to only output 1080i via component cables. Do this in the blu ray players setup menu.
Feb 23, 2009 | Hitachi 61SWX10B 61" Rear Projection...
May sharp lc-52sb55u
Well, there is a way to have the clearest possable picture. Get HD cable TV box that is HDMI compatable and watch only HD channels. Or buy a blu-ray player, hook it up via HDMI and only watch blu-ray disc in 1080p!
Jan 06, 2009 | Sharp LC52SB55U LCD TV
Aquos Turns off by itself
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, you can order the part over EBay, not hard to install just unscrew/unplug --- plug/screw..
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-32SH12U TV Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
