I recently received Error code FSE1 on my Whirlpool Super Capacity 465 Self-Cleaning oven which indicates the automatic door lock mechanism is not working properly. Before you spend money to possibly replace parts try doing what I did which took care of the problem nicely. With the oven door open locate the latch lever at the top of the oven. Using your hand slide the lever to the right just as it would to lock the door. In my case the lever was simply stuck and required a bit of force to get it to move. After you get the lever to move repeat the action several times. While doing this I found there to be a clicking sound which seemed and sounded normal. Close the oven door and start the self-cleaning function again. It worked for me - I hope it works for you!
Suggest obtain the owner's manual for your oven and locate the
FSE1 error code in the trouble shoot section then follow the corrective steps.
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
SOURCE: ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced. if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! good luck.
SOURCE: WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
SOURCE: code fse1 comes up when a few minutes after pushing start to cle
F5 - E1
Self clean latch will not lock
1. If door latched:
2. If door not latched:
3. Measure door switch (door open = switch open small low voltage
terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light
contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control.
Press and hold any key for 1 minute to clear R failure code from memory.
F2 will appear. Press CANCEL and observe for 1 minute to ensure
operation is correct.
6. If failure remains, disconnect power and replace control.
SOURCE: whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that
you’ll need to check the door latch/switch and replace the part that has gone
bad. Please do rate the solution
if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
