2006 Chevrolet Trailblazer Logo
Anonymous Posted on Feb 13, 2011
Engine light on sometimes 2006 trailblazer - 2006 Chevrolet Trailblazer
Ryan Lutton
Level 3:
  • Chevrolet Master 1,267 Answers
  • Posted on Feb 14, 2011
Ryan Lutton
Chevrolet Master
Level 3:
Answers
1267
Questions
Helped
593356
Points
3608
Invest in an OBDII reader. They range in price from $20-$400 and can do anything from just read codes when the engine light goes on, to real time data. Intermitent engine lights are tough, so next time it goes on, you can hook up your reader and find out what it is right then and there. Even for future problems, you can keep your mechanic honest by knowing exactly what's wrong with the vehicle. Buying a code reader will pay for itself the first time you use it.
Why doesn't my trailblazer turn on when reduced engine light is on?
That is to protect the engine from overheating and ruining the engine. You may have a cooling system problem. Sometimes as simple as old antifreeze, or a thermostat is bad. Also check for soft hose when the car is cool. If they are old it may not be circulating properly.
1helpful
Shutting off
You have a check engine light on
We have been checking for codes for the last
30 years, the day one of those lights on the dash
Then have a shop diagnose the codes,find the fault & repair
8helpful
2answers
How to reset oil warning light on a chevy trailblazer ls 2006
The way to reset the oil light on your Trailblazer is.You first turn the key on but do not start the vehicle.Press the gas pedal 3 times all the way to the floor within 5 seconds.The change oil light will flash several time then go out.The oil life has been reset.Remember don`t start the vehicle just key on engine off.Hope this helps.Good luck.
1helpful
What can cause the check engine light for a bank 1 lean in a 06 chevy trailblazer to come on repeatedly? it has been taken to repair shops and the dealer. They fix and reset the codes. but when i turn the...
What have the repair shops and dealer diagnosed so far? And what have they done to "fix" the problem? A lean condition sometimes is caused by a vacuum leak in the intake.
2006 TRAILBLAZER CHECK ENGINE LIGHT GOES ON AND BACK OFF IN I/2 SEC. THEN THE CRUISE GOES OF F AND SOMETIME THE AIR. I TOOK TO A SHOP AND THE COMP. HAD NO CODES IN IT. I HAD THE IGN. SWITCH REPLACED THIS...
O.k the best advise I can give is to disconnect the battery possitive terminal for about 15 min. This should reset your dash lights. Drive for a few days and see if they come back on. This time they might send a code to you. Try you Autozone or prts store to have it scanned. They do it for free.
06 Trailblazer that will not start
Try putting the geashift in neutral when starting the truck. If it starts every time this way, your neutral safety switch or park interlock switch is broken. Let me know if this helps :)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
