Question about Peg Perego John Deere Gator HPX Ride on Toy
The charger says that the battery is charing and the green light is on after charging for over 6 hrs it still dont want to move whenever you push the gas. So i tried unplugging the battery and left the charger plugged in and the green light was still on is it the battery or the charger?
Posted by sarahmatt703 on
Anonymous
    Sniper:
  • 70 Answers
Most likely Neither. It is usually the Gearbox has gone bad. It is easy to replace, Peg Perego has a wonderful tech support they can walk you through it 1800-728-2108 if you need parts they handle that too, or you can go to www.mypegperegoparts.com
Posted on Mar 01, 2011
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
Rechargeable ratchet won't charge
Sounds like your cell is dead and you need a new battery
Mar 15, 2012 | Saws
I HAVE A SANYO CHARGER NC61 WHICH SHOWS TWO GREEN LIGHTS WHEN CHARGING, HOW DO I KNOW WHEN THE BATTERIES ARE CHARGED/
Generally speaking,six hours is enough to charing SANYO Battery with full power ,when it is full it will stop charing automatically.
Feb 09, 2011 | Cameras
Just got this little dirt bike from a yard sale. Trying to figure out charging the battery. When I put the charger into the outlet, the little green light comes on. Then when I connect black charger end...
the charger led should turn orange or red when charing then turn green when finished charging, but without knowing the model of the charger its had to say
Dec 12, 2010 | Peg Perego 12v Battery
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Apr 03, 2010 | Air Hogs Radio Controlled Storm Launcher...
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
Lawrence Oravetz
john h
ray gallant
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
