If you've been using tap water, then you likely have hard water deposits (scale) on the heating element, which will eventually cause it to stop working. Try cleaning it with an overnight vinegar soak, or whatever is suggested in the manual if you have one. Once most of the deposits are gone, it shold work again. In the future, this will not happen if you use distilled (not to be confused with filtered) water. Good luck!
