Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My oven wont heat up after i reset it - Kenmore 40494 / 40495 / 40499 Electric Single Oven
Posted by hultman77 on
Anonymous
    Champion:
  • 235 Answers
When you refer to resetting it are you talking about turning the mains power off and then back on?
Or are you talking about resetting the electronic timer? The electronic timer must be in the manual mode for the oven to work. Turn the oven on and play with the timer. When the oven indicator light comes on you know the oven is working.
Posted on Feb 13, 2011
My whirlpool RBD305PRS00 double oven wont heat up and is locked
The door and controls lock when the oven temp is very high or when on pyrolitic cooking if that is available on your oven. If the controls wont reset or the door wont open try turning the power off for about 30 minutes and then try again. reset the clock and hopefully the oven will return to normal..
Aug 26, 2014 | Ovens
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
May 12, 2014 | GE JTP45 Electric Double Oven
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
My oven wont come on and i know there is a problem with the electronic programmer, can i reset it or not use it at all
If you cannot reset the oven timer, then it will not heat the oven.
This being the case, then it is possible in some cases to bypass the timer, or the alternative is to to replace the timer.
Jan 25, 2011 | Zanussi ZBF360 Electric Single Oven
The reset button goes off and the oven wont heat up. This has happened twice.
If the reset is in the machine then check the cavity fan. It must run to keep the cavity cool.
Oct 27, 2010 | Electrolux 30" Built-In Double Electric...
F9 reset, no heat and door wont lock for cleaning. no heat for regular oven either
Hi. The unit is programmed to not operate,or heat, when there is a serious fault within the door latch assembly. This F-9 code, represents a failed door latch assembly. This device must be replaced. Once replaced, the unit will operate correctly.
NOTE_ Try to reset the mechanism. This can be done by shutting down the power, or unplugging for five minutes. Once the five minutes have passed, simply, re-introduce power to the unit, and observe. if the error code returns, replace the door latch assembly.
Dec 09, 2009 | Amana AOCS3040SS Electric Single Oven
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
Top Kenmore Ovens Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
