Question about Leviton Electrical Supplies
Can't get my switch to operate the outlet just bought a 5625 switch i have two wires coming out of the wall i want to plug a light in the outlet and have the switch control the power to the outlet.
Anonymous
    Scholar:
  • 99 Answers
  • Turn off the power to the receptacle that will be replaced by switching off the circuit breaker in the fuse box. Check that the battery is good in a circuit tester. If not, replace the battery. Place the tester's two ends in one set of the receptacle's slots, then the other set. The light on the tester should not come on. If it does, the correct circuit breaker has not been switched off.
  • 2
    Take off the receptacle's face plate by first removing its screw. Detach the two screw securing the receptacle to the box and pull out the receptacle. Loosen the receptacle's terminal screws and pull away all wires from the back of the receptacle. Take out the receptacle (if working properly, it can be reused). If the ends of the wires are chewed up after removing them from the existing receptacle, cut them off with wire cutters. Strip off 1/2 an inch of insulation from the ends, using wire strippers. Bend them into loops with the pliers.
  • 3
    Bend the copper ends of all wires into a loop, using a pliers. Connect the white wires to the silver terminal and tighten the screw to the wires. Connect the black wires to the gold terminal and tighten the screw to the wires. Connect the bare ground wires to the ground terminal and tighten the screw to the wires.
  • 4
    Push all cables into the back of the box, followed by the receptacle. Attach the receptacle to the box with the two screws. Hold the new faceplate in position and install the screw. Turn on the power at the circuit breaker.
  • HOPE THIS HELPS YOU...Jim...Please leave a comment
    Posted on Feb 13, 2011
    Testimonial: "Thank you your info was great!"
    Jdvillanueva
    • 2,098 Answers
    Two wires coming out from the wall is the line 1 and line 2 from the breaker box. If you wan't to power on the outlet through the switch here are the steps. Connect line 1 to the outlet directly, and line 2 to the switch. Get one spare wire to jump the open slot from the outlet and switch and you're done.
    Hope I help you.
    Have a nice day!
    Single pole switch, one black wire, one white wire and a ground controls two the bottom half of two different outlets. I replaced the old recepticals and didn't,t pay attention to how they were wired
    It doesn't matter how the receptacles are wired it is AC, The switch should just be in the line between the source and the outlet and when turned off open the circuit. Use a voltage tester to see if power is coming into the switch. If power is coming in and not going out then you have a faulty switch.Recheck the wires going to the receptials and make sure one has not come loose.
    Testing household outlets with 3 light tester
    Have you tried to determine if the problem outlets might be controlled by a wall-switch? This could be the case if separate black wires coming into the box are being used for the different outlets.
    Wall light switch timer inline with Extension cord GE 15313
    Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
    If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
    How to connect 2 lights from wall unit to wall plug
    the electrical department in Home Depot or Lowe;s have double , triple adapters for outlets. BUT You need an Electrican to rewire wall switch for a switch control of an outlet....just like in a living room when you enter from outside.. it turn your lamps on.
    I have three wires, two are black and one is white. I want to have the outlet active and the switch control an overhead light. How do I connect the wires?
    Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
    1helpful
    I have an outlet that I want to convert to a light switch and an outlet on the T5625. I can not get the light switch to work. I have a Black hot and neutral with a grond. how do I hook up ht light portion?
    Electrical devices have color-coded screws.
    Electricians don't guess, they test.
    You have tested the wires.
    1) Combo switch-outlet device screws are dark - brass - silver - green
    Hot to dark
    Neutral to silver
    Load wire (wire that goes to light, fan, motor) to brass
    Bare ground to green screw
    2) If you want switch to control the outlet on the combo device.
    -Device must have 2 dark screws
    -Look at dark screws, there is a break-away fin that connects dark screws.
    -Remove break-away fin.
    --Now there is one dark screw for the switch part of device, and one dark screw for outlet part.
    -Connect Hot to dark-for-switch.
    -Run jumper wire from brass screw to dark-for-outlet.
    -Neutral to silver
    -Switch on combo device will operate outlet on combo device
    Add a comment for more free help.
    Also take advantage of fixya phone service.
    For a price, expert speaks with you over phone while you work on wiring or any do-it-yourself project.
    Fixya is always less expensive than a service call.
    I have a Leviton 5625 (rocker switch and outlet) and am trying to replace an existing light switch with it. I have a black and white wire tied to the top and bottom left screws, respectively, in the...
    Ok - you have to figure out which two wires are supplying the power. Then which wires go to the outlet. Then the last wires should go to the light. Connect all the white wires together. then the black from the power cable goes to the black of the outlet. Add a short wire to the black group and put it to one side of the switch. put the black wire from the light cable to the other side of the switch.
    3helpful
    Wiring a leviton 5625-W switch receptacle combination
    You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
    You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
    New oven, new installation. power at wall outlet, no power at ove
    Open wire...either ground or neutral.
    Lights are 110volt...and possibly there is a disabling feature due to open wire, as stated above, not allowing oven to operate.
    When ground and/or neutral are provided all should work.
    Feb 28, 2009 • Ovens
    Electrical Supplies Logo
    Top Leviton Electrical Supplies Experts
    john h
    Mike
    Gil Shultz
    Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
