Sizzling noise coming from APC Back-ups XS 1300
Posted by aceking_23 on
Anonymous
    Brigadier General:
  • 10,406 Answers
Turn it off IMMEDIATELY -- something has short-circuited, and something is BURNING.
Disconnect it, and responsibly recycle it. Purchase a new one.
Posted on Feb 12, 2011
APC XS 1300 getting A04 error code. Pulled battery and reinserted plugged unit back in and it seems to be working fine now. But for how long?
Good that you got it working. How old is it? Warranty? What does the error code mean? If it is a charging error, the charging system may have a problem. Talk to customer service or email. They like to know how their products are doing. I would guess there is a battery charge level meter via their software and a USB cable connection? If so, keep watching It should give you early warning of battery failure. Or better yet, create your own "controlled" power failure and see how long the battery supports system power. Otherwise, take the battery to battery store. They can test it for you and tell you condition status.
Feb 28, 2015 | APC Back-UPS XS 1300 VA Tower UPS
APC UPS XS 1500 exploded after installing battery
batteries were put in wrong. Nothing else it could be. Most likely is was your DC capacitors blowing up.
Feb 19, 2015 | APC Back-UPS XS 1500 - UPS - 865 Watt -...
How do I Remove battery on apc battery back ups bx900R?
If the batteries are swollen (overhead damaged), I would use a screw driver to gradually lever it out.
May 21, 2014 | APC Back-UPS® XS 900 (BX900R) UPS System
My apc ups 880va is not working online .what is the problem?
Have you change the battery? most APC ups just need to change the battery for it to work again.
Jan 20, 2013 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Apc xs800 new batteries
I Bought two RBC32's and had to hook them up to the connector and did it wrong on the first try. Make sure you connect the yellow to the Red terminal on one battery and the Black on the other, then connet the remaining red to red on one and black to black to the other. Once I did that and plugged it back in everything worked fine.
Apr 06, 2012 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
My Apc xs 1300 keeps chirping. This happened after a power outage in our building. is the battery fried?
Replace the batteries. This will fix the problem. Call me at Gruber Power Services for Free tech. support. 800-658-5883 x256 ask for Eric
Aug 22, 2011 | APC BACK-UPS XS 1300VA LCD 120V...
Have a APC xs-900 that indicates overload and there is nothing plugged into it. New battery did not help.
change the internal fan its a 18-24V type change it with a ball bearing type and yes a 12 volt will also work, with 120v input fine and under medium load the fan is only supplied with about 15 volts and only reaches 24 volts if the load shoots up or there is a power fail situation
Sep 09, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
The battery on my 1300 xs keeps saying
Check your wiring make sure the clip has not come on done and its staggering connection. I have the exact same make/model had the same problem it was the clip. Also, if that doesnt work remove the battery and have it tested for bad cells. If you need further help IM me on AIM @ candidate4death.
Cory
Jul 26, 2010 | APC Back-UPS RS Battery Backup (apw...
Computers & Internet Logo
k24674
