Question about Samsung 4 Channel Dvr
I installed a Samsung SDE 120 4 camera system at my father's and finally got online after typing in IP address and the next day internet explorer is not able to find it. we have DSL through AT&T...please help...
Posted by caddy64 on
1 Related Answer
SOURCE: i followed the instructions. i took cisco. i
http://cowboyfrank.net/webcams/HowTo.htm
http://www.ehow.com/how_5814774_open-webcam-through-internet-work.html
Above is a couple of "How tos"
Ok, first one must understand one thing, and that is one cannot access an EXTERNAL IP address from BEHIND, only internal access to the camera can be obtained however, one can "see' the webcam across the "Home network" but to be able to "look in"as it were one must obviously be "outside" looking "in"as it were. So accordingly the only way to test the webcam is to try to access from another EXTERNAL IP address, IE: from someone else's internet connection.
Another way, that I use to test, is if one has a broadband connection, then also usually one has also a dialup connection, one can in this instance test the camera, on the "Broadband" IP from the "Dialup" IP.
what you also need to do, is Forward a Port so that the camera is available for external access, use this site below to assist you.
http://portforward.com/
Posted on Feb 24, 2011
No picture,circle with slash
This means that there is no camera signal getting to the DVR. Could be a bad camera, or camera power supplies, or connection to DVR or camera.
Feb 13, 2013 | Samsung SDE-120n 4 Channel DVR System
How do i view my security system on line using my apple laptop system is sde 4001
You won't be able to access the system from a different network without changing some settings in the router. You will need to find out what ports the security system uses. If you bring up a web page to monitor/configure the system, then you'll most likely use port 80 (HTTP) or port 443 (HTTPS). If you see "www.something.com:3948", the port is the number after the colon.
You will need to go into the router and enable port forwarding to the IP address of the security system.
Oct 22, 2012 | Samsung SDE-4001 8 Ch DVR Security System,...
Internet Explorer cannot display web pages!
have you got an IP address? go to run>cmd and type IPCONFIG and press enter
If the IP address starts with 169. then you have no connection to the internet or your router
Have you restarted both devices (PC and router) ?
Sep 01, 2011 | Computers & Internet
DVR SDE 120 can't reset 4321 thanks
There is no mode or channel 2 button on the SDE-120
Apr 27, 2011 | Samsung 4 Channel Dvr
Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
My production code dont work i think a trial verson of vista was loaded on and now only runs in safe mode
You can extend the 30 Day Trial to 120 Days by following method. Start computer in safe mode. Open the Internet Explorer type c: at the address bar of the Internet Explorer and press enter It will ask for the UAC - User account Control. Click continue on that. Now type C:\Windows\System32\ into the address bar. then find the file cmd.exe and right click the file and click on run as administrator. Command prompt will open. Now type the command slmgr -rearm and press enter Type the command [ slmgr -rearm ]and enter again. Do the above step three times. The windows will work for next 120 days
Apr 17, 2010 | Acer Computers & Internet
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
I can not get my Belkin F5D7050 to connect to the wireless router Belkin F5D7230-4. I am about to throw the whole thing out. What do I do?
Well, I finally got the F5D7050 to connect to the router and it says it is connected to the internet. I had to go in and change the IP addresses, instead of it allowing to search for the IP addresses. Now the problem I have is that the internet explorer is not registering that I am online. I have restarted the computer a couple of times, but internet explorer still will not connect. It just continues to show the unable to display the page. The computer in question is on XP. Any advise would be greatly appreciated.
Oct 05, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Samsung 4 Channel Dvr Logo
371 people viewed this question
Top Samsung Home Security Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Bill
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
