You can re-install your Belkin router even don't have cd software. There is a manual or web-based method to setup Belkin router without cd disc. You just need to follow the steps given below:
Take an Ethernet cable.
Connect it from the network-port on your computer to one of the 'LAN' ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Enter http://192.168.123.456 (or whatever values you saw, above)
Login to your router
Run the "Setup Wizard"
Run the "Wireless Networking Setup Wizard"
Belkin has a great support site and this link here will take you a page where you can download a new manual, firmware updates, and even troubleshooting help with setting up the router with Comcast, Bell South, and Cox cable systems.
Good luck to you.
Bessie necro posts again....
OP Karen, you do not need to do anything to any routers, if your formated 1000 PC
wired it just works as it did, (Ethernet cable)
wires still work now
TV to Belkin wifi works.
CELL phone to BELKIN wifi still works.
any PC to BELKIN (1 of many fail)wifi
all still work but 1.
so my guess is you NEVER wrote down your wifi credentials and the reformatted PC can not connect.
well log in to said router and read the WIFI page !
SSID NAME (use a name only YOU KNOW)(setting it day1)
WPA2 selected.
and pass phrase, if can not see it change it to a new one and this time write it down.
this router is trash it is NOT SECURE at all. a very dangerous device.
