Question about Dremel 300-N/55 300 Series Tool Kit
The catch inside the tool that lets u take the bits out is worn and needs replaced. how do i get anew one.
Anonymous
  • 376 Answers
Your best bet would be to go to dremel web site and do a replacement parts search for that model.It will bring up there home page .From this page you can go under manuals and parts list and a place to order the part from and a contact to make sure you get the right thing.Hope this helps you out.
Posted on Feb 13, 2011
I have a vw t5 i shut the rear door but it didnt catch on the lock , i need to know how to remove the rear door lock from inside and what tools ill need , thanks
It can depend on whether it is the twin rear doors or the single swing up tailgate.
Tools will be Torx bits (or Torx keys), screw drivers and a set of pliers, (grips).
If it is the 'catch loop' it hooks into it is simply bolted into place using torx bolts. You might need to remove some plastic trim to see the bolts.
If it is the actual mechanism, it takes a bit more work. You will need to remove the trim panel on the inside of the door, usually screws around the edges. There might also be a plastic skin behind it.
The lock mechanism is bolted into place from the outside but is mounted inside the door panel. It will be a pain in the **** to get out as there are connector rods to the door handles you will need to disconnect as well.
Apr 20, 2018 | Cars & Trucks
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
Sep 21, 2014 | Dyson DC35 Handheld Vacuum
How can I buy a replacement door for a 302 dishlex ?
I was looking for the same thing myself for our Dishlex 300 a few months back. Our problem was 1/ the handle wasn\'t releasing the door catch,
also 2/ the micro switch in the catch wasn\'t getting pressed down properly to tell the machine the door was closed, so the dishwasher wouldn\'t start. Both problems were related to the plastic ramp inside the door being worn where the tongue of the catch goes in.
We couldn\'t find one in NZ, so I made a tapered flat piece of wood to push the catch down between the main body and the door whenever we want to open it.
For the switch problem it was a bit harder - I opened up the plastic box at the top front of the machine (with the power off of course) and built up the plastic ramp that triggers the switch, using glue and then a file to shape it after the glue hardened.
I hope this is helpful.
Cheers.
May 26, 2014 | Dishwashers
When printing, the paper in the tray does not feed. It lifts but doesn't catch.
The printer's pickup roller needs to be cleaned or if its worned needs to be replaced. The pickup roller is the little blue rubber roller behind the cartridge. If it still doesn't catch you'll need to strip the machine down until you get to the springs that lifts the papertray. Stretch the springs a bit. This will cause the paper to be pressed against the pickup roller. Re-assemble the machine and try it.
May 16, 2011 | HP LaserJet 1300 Printer
How do you adjust car door that needs to be sort of lifted to close. noemally, it gets slammed shut a couple of times to close right.
The usual cause of a hanging door is a worn door hinge or two. You might be able to loosen and lift the two hinges, at the front of the door, a bit.That might allow the door to close better but the best solution is to replace the worn hinges.
Jan 14, 2011 | 1998 Chevrolet Blazer
When i press the on off swith my flashlight wont stay on unless button is pressed.
The button is worn out and needs replaced; the catch mechanism inside the button is either broken off or worn out so much that it won't catch. In most cases, it is less expensive to replace the whole light. All things break eventually!
Rate this solution!
Jan 04, 2010 | Streamlight Camping, Backpacking & Hiking
Sheared Bolt Head on Boat Propeller Housing
need more detailed info like year make model bolt location? the reason, I would know how long and wide the bolt is that is broken off. Typically when a bolt gets broken you have several steps to follow and two tools to purchase to get broken bolt out. 1st The best tools to purchase and will save you a lot of headache is a reverse drill bit kit with easy outs. They are expensive but well worth the cost. With every drill bit the kit will have a easy out to match. I myself have a large kit that I use weekly because of salt water engines. Make sure you get a high quality set (snap-on, mac tool etc..) because if it breaks off you have double the work. 2nd small chisel pick and punches. (1) Take a center punch and hammer and dent the bolt for a starting point for your drill bit. (2)Again if I knew the location of the bolt I would know how big it is. Because you have to stop drilling at a certain depth so you don’t drill into the case. If you have another bolt you have taken out of the case that you believe is the same length, measure it and drill only half the length of the bolt. (3)You want a small drill bit to start, about half the size of the Circumference of the bolt. Remember these are reverse drill bits so put your drill in reverse and go very slow with light pressure. Let the Drill bit do the work. (4) use a spray lubricate like WD-40 to keep the drill bit and bolt cool, to much heat will dull you drill bit. These bolts are stainless steel so it will be a long time before you get a decent hole. (5) What I hope happens, when I’m using the drill bit is that the drill bit catches enough of the bolt and turns it out as I’m drilling. But with rusted bolts it’s a rare occasion . When you come to the stopping point of your hole clean it out and use the easy out that comes with the kit. You do not want to break the easy out in the hole so use light turning pressure. If it doesn’t come out with light pressure You need to stop and go to the next step.(6) Take the next size drill bit out of the case and start drilling again slowly with lubricant. When you reach the stopping point use the matching easy out.(7) keep following these steps until you get almost to the full diameter of the bolt. Remember bolt threads are male to a female thread inside the hole so you don’t want to drill out the threads inside the hole. (8) if you reach the female thread inside the hole and the bolt still hasn’t come out use the chisel pick softly to clean the tread inside the hole. At this point you will need to purchase one more tool. A thread tap. Take a matching bolt and match diameter and thread pitch and clean out the treads that may have been damaged with the chisel pick.(9) when the job is finally done and your ready to put the housing back on use as gasket sealing compound on all your bolt to protect them from rust do not use thread locking compounds. Have fun.
Nov 03, 2009 | Boating
How do you put new twine in the ryobi 725r
you have to dismantle the bottom part by unlocking it maybe with an ppropriate tool supplied and y doing so anticlockwise
the round pat will come off and you can then chahge the line with anew one or replace it with anew bobbing
sometimes the line does not come out and by deplacing part it will releae
most times ther is lot of line left inside and you just need to release it
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Kenmore washer will not agitate or spin and makes a loud noise
I will cross my fingers that it isn't your transmission. One thing though that it could be is the agitator dogs. Pop of the top of the agitator and look down inside. You will see a ring of teeth and 4 little plastic pieces that sit inside. What these do is catch the agitator when it agitates and spins. Pull them out and see if the teeth on them are worn down and if they are replace them. If it is making noise though it is most likely going to be the transmission that is the problem. Try to find one that is refurbished as it is about 100 dollars less then a new one. If you have any other questions or need help with replacing the transmission let me know. I can give you a step by step walk through on changing that out. It's a pretty simple process. Let me know too if this was helpful for you. Good luck and I am glad that I could help you out.
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
Dremel 300-N/55  300 Series Tool Kit Logo
Top Dremel Tools & Hardware - Others Experts
Mike
Sheldon Dedek
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
