Question about Denon Audio Players & Recorders
Trying to reboot a Denon AVR2309. Volume cuts on and off on some channels. DVD player works perfectly. I've done this before but want to make sure I'm doing it right. I can't find my manual. I turn the 2309 completely off and even uplugged the power cord. While holding the speaker and input button I turn the 2309 on and see the display screen blink on and off for 10 seconds. Is that the right sequence?
Posted by gibsones335t on
David Dunn
  • 8,546 Answers
Register for free and download sthe manual...
http://www.retrevo.com/support/Denon-AVR-2309CI-Receivers-manual/id/21864dj589/t/2/
That seems to be the correct sequence. It's on page 56.
As far as your volume cutting off problem goes. "Some" channels? Which? Is it source-specific? If so, investigate the source.
Maybe look for loose speaker wires.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 13, 2011
I have an audiosonic KM3608N DVD player and an LG TV. I have perfect sound when watching TV but seemed to have pressed something on either TV or DVD remote that has caused the DVD player to play at...
Please go to audio output menu on your DVD screen check them and when on the DVD channel check your audio input menu. You could have turned on the volume limit on your DVD settings menu
Nov 02, 2017 | Car Audio & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
I have a denon amplifier Model : AVR-2805G when i turn off the amplifier the volume for DVD player cannot be increased pls advise
you have to hook the dvd player directly up to the tv in order to get volume. when you turn the amplifier off, it's going to cut off the volume to the dvd player.
Jul 31, 2009 | Audio Players & Recorders
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
May 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
[email protected]
Apr 12, 2008 | Denon Audio Players & Recorders
Top Denon Audio Players & Recorders Experts
tina gallow
midland10
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
