SOURCE: EPSON Perfection 4870 Photo Scanner - Driver for vista
Kindly check out the URL and you will get the driver http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=28461&infoType=Downloads
SOURCE: Epson 2400 scanner red light flashing
Normally any new scanner fresh from the factory has a 'lock' which prevents damages due to transportation. Ensure it is unlocked.
S. Mohan
SOURCE: Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
SOURCE: Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
SOURCE: I have an Epson Perfection V700 Photo scanner and
Yes the scanner is compatible with a downloaded driver from epson. however some of the supplied third party software may not be. Also with MACS the push button scan may not work.
