SOURCE: Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
SOURCE: Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
