Question about Nintendo Video Game Consoles & Games
The wii console light does not light up. I tried plugging it in to a different outlet and it is still not working. in the past i have had to plug the console in to other outlets and it would then work properly now it is not working at all. Help
Posted by naas48858 on
Derek Carden
  • 783 Answers
Take it into a game crazy or something and have them look at it, nothing you can do yourself on this one..
Posted on Feb 12, 2011
Fixya com
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Perform an AC Adapter Reset. To perform an AC Adapter Reset follow these instructions: Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. The AC adapter must remain unplugged at both ends for a full two minutes.
  2. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  3. Check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If the AC Adapter shows signs of physical damage and needs to be replaced, a replacement can be purchased from Nintendo's online store.
  4. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
If these suggestions don't work try visiting Nintendo's help pages at: http://www.nintendo.com/consumer/systems/wii/en_na/ts_system.jsp
Apr 21, 2013 | Nintendo Wii Console
Wii wont power on
Wii Console Won't Turn On, and Has No Power Light
Situation:
The Wii console won't power on, and the Power LED is unlit
The console powers on, but shuts off after a few seconds/minutes
Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
Oct 29, 2012 | Nintendo Wii Console
Breaker tripped and now my nintendo wii wont turn on
Few things to try:
1. Different Outlet. Plug the console into a different outlet in your residence. If the Wii turns on, the outlet is dead. I would recommend an electrician to fix the outlet.
2. Try a different power adapter. You could purchase another power brick or get one from a friend and use the new one to try and power up the console. Also try in a different outlet (step one) to be sure
3. If none of this works, the console may have just received too much power and burnt out the power supply. Contacting Nintendo. Information below:
http://www.nintendo.com/corp/contact.jsp
Mar 06, 2011 | Nintendo Wii Console
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
May 31, 2010 | Nintendo Wii Console
My wii wont turn on the power does not show a light
Try a different outlet to make sure the outlet you have it on is good or not.
If a different outlet didn't make it turn on then at that point, try another ac adapter for the Wii. If a different adapter doesn't work then you know the main board inside of the Wii is bad.
Aug 08, 2009 | Nintendo Wii Console
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
There is no power to the Wii console
Unplug all cords to the wii, also unplug the adapter from the plug let stand for 5 mins to reset.
Jun 14, 2009 | Nintendo Wii Console
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
